Polish Aluminum
hdrider19
PostPosted: Mon Mar 13, 2017 8:20 am    Post subject: Polish Aluminum Reply with quote
Polishing aluminum is 99% sanding. You will have sore fingers by the time you are done. If you are doing wheels I would suggest sand blasting to remove any paint or finish from the metal before you start. This is a set of wheels I did for my Jeep.
picture host
I know,pretty rough but I got them free! I used a wire brush to remove the flaking paint. Careful with this. Aluminum is soft and scratches easy. Never use a wire wheel on a drill. It will eat the metal surface.
upload a gif
After you have a bare metal surface it is time to start sanding. If the surface is smooth start with 320 wet. If it is a flat surface use a sanding block to keep it flat. Sand the entire surface until it has a smooth even finish. If your wheel has curb rash or pitting it will need to be sanded with rougher paper first. Now switch to 400 or 600 and do it all again. Keep sanding with finer grit paper to at least 1500. The smoother you get the surface the more mirror like the finish will be. After all sanding is done wash all the residue off with soap and water. I use Mothers Aluminum polish and a soft clean cloth. Rub it in a small area and then buff it off with another soft cloth. I use an old bath towel for this. Don't let the polish dry on the aluminum. Keep working small areas till it is all done.
screen grab
I did these wheels in a weekend. Use a good wax after all the polishing is done. It will keep them looking great for a long time.
87 924S
hdrider19
PostPosted: Tue Mar 14, 2017 10:07 am    Post subject: Reply with quote
Ready for more? Finger tips not hurting yet?
uploadimage
87 924S
hdrider19
PostPosted: Wed Mar 15, 2017 8:56 pm    Post subject: Reply with quote
free uploader
87 924S
hdrider19
PostPosted: Thu Apr 13, 2017 11:51 am    Post subject: Reply with quote
I am about to start polishing these 7" phone dials. Dropped them off at a sand blaster today. I will show step by step pics of the process as I go. The wheel on the right has a curb grind at the top in the pic. I will take it to a friend with a tig welder to fix that before I get started. I picked them up for $20 each.
adult image upload
87 924S
hdrider19
PostPosted: Sun Apr 16, 2017 11:14 pm    Post subject: Reply with quote
I got my wheels back from the sandblaster. Why sandblast first? I think these pics say it all. They look like new castings. It leaves a grainy texture on the surface but it lets you see exactly what you are working with. I will prime and paint the back side of the wheel to seal the metal and prevent corrosion.
image sharing sites
87 924S
hdrider19
PostPosted: Tue Apr 18, 2017 12:32 pm    Post subject: Reply with quote
After getting my wheels from the sandblasted they had some problems. 1 had some small pitting in the surface.
image hosting 5mbcertificity.com
The other 2 have larger pits(craters). I will take the better of them and see if they can be filled with a tig welder. This was hiding under the primer. The sandblasting left a grainy surface over the whole wheel.
gifs uploadcertificity.com
I had to start with 220 grit sand paper wet sanding to smooth the surface.
imagescertificity.com
I spent about 2 hours sanding this wheel and have most of it smooth now. It was starting to get dark out and I am doing this in my driveway so I had to rap it up for the night. I couldn't resist a little preview so I jumped ahead on 1 of the oval slots and put a shine to it.
photo sharingcertificity.com
And I warned you early on about sore fingers. This was also why I stopped for the night. 220 grit will rub thru skin! A small sacrifice for polished wheels.
image upload with previewcertificity.com
87 924S
jazz guy
PostPosted: Wed Apr 19, 2017 4:24 am    Post subject: Reply with quote
I'm enjoying your thread. I know from polishing a set of 928 wheels how time intensive the process can become. Lot's of patience needed, along with a big dose of elbow grease and yes, plenty of sore fingertips. Good luck!
'81/'81/'82
PostPosted: Wed Apr 19, 2017 8:20 am    Post subject: Reply with quote
uploadimage
Nice mug
hdrider19
PostPosted: Wed Apr 19, 2017 11:56 am    Post subject: Reply with quote
Thanks for the comments. Dan, I had just finished polishing the water neck and sat down with my favorite mug of coffee. I saw it reflecting on the water neck and had to take a pic. I finished wet sanding with 220 grit and then started over with 320. When hand sanding I cut the sheet of sand paper into 1/4s and then fold in half. After sanding the whole wheel again it is getting brushed finish and starting to reflect colors in the background.
free photo hostingcertificity.com
imgurlcertificity.com
photo hosting sitescertificity.com
I rubbed in some polish in the area between the slot just to see how it is coming along and as you can see it is starting to show a reflection. You can still see the sanding scratches tho.
image rucertificity.com
This is the brand of polish I prefer.
screen shot windows 7certificity.com
My wife brought these home from her office and I must say they help keep my finger tips where they belong.
upload picscertificity.com
87 924S
hdrider19
PostPosted: Sun Apr 23, 2017 2:28 pm    Post subject: Reply with quote
I picked up some 2" flap sanding wheels in 180 grit.
They made quick work of smoothing out the oval slots.
image sharingcertificity.com
Next came a full resand with 400 and then again with 600.
87 924S
hdrider19
PostPosted: Mon Apr 24, 2017 1:52 am    Post subject: Reply with quote
Next step is 800 grit. After sanding I rubbed on some polish to see how it was coming along. It got a pretty good shine but it still has a little cloudiness in it. I will sand it again with 1500 grit and see how it comes out.
screen shotscertificity.com
87 924S
hdrider19
PostPosted: Mon Apr 24, 2017 2:27 am    Post subject: Reply with quote
I think it's done now. After 1500 grit resand I rubbed on the polish and it looks pretty good to me. Now I need to do it all again 3 more times. Ouch!
windows screen capturecertificity.com
upload a gifcertificity.com
picture uploadcertificity.com
how to take a screen shotcertificity.com
87 924S
PostPosted: Mon Apr 24, 2017 5:31 am    Post subject: Reply with quote
very nice
hdrider19
PostPosted: Mon Apr 24, 2017 9:38 am    Post subject: Reply with quote
I did the same job on the center cap and then polished. Sand blasted first to get a good clean surface. I was thinking about painting in the logo after but I think I like the raw finish in it. I also left the lug nut holes raw so they go together.
upload fotocertificity.com
87 924S
PostPosted: Mon Apr 24, 2017 3:03 pm    Post subject: Reply with quote
Hard to believe it's the same wheel as at the beginning of your post!
Nice work.
