Speedometer gear replacement.
Goto page Previous  1, 2
mikeycrum14
PostPosted: Tue Apr 11, 2017 1:24 am    Post subject: Reply with quote
try krazy glue. seems to work well in these situations.
1981 924 - Alpine White
First car!
Fresh tune up, stage 3 racing clutch, stock otherwise, 5 speed trans. - SOLD
Ozzie
PostPosted: Tue Apr 11, 2017 8:46 pm    Post subject: Reply with quote
tried that, lasted a few months.
I am about to pull it out again while changing the cable (always had a jumping needle)
Its AUTO and its BLACK
Montego Black on black/red
mikeycrum14
PostPosted: Wed Apr 12, 2017 1:26 am    Post subject: Reply with quote
krazy glue... works wonders.
First car!
mikeycrum14
PostPosted: Wed Apr 12, 2017 1:27 am    Post subject: Reply with quote
apologize for the double post*
have you tried maybe taking the gear off and sanding the pin to rough it up, then glue inside the gear, press it on, and then put huge glue drops on the ends and let one dry then flip over and repeat for the other side of the gear.
First car!
Ozzie
PostPosted: Wed Apr 12, 2017 7:10 am    Post subject: Reply with quote
yes, used a small grinding tool.
Thinking I might deform the end (flatten with hammer) slightly
mikeycrum14
PostPosted: Thu Apr 13, 2017 1:37 am    Post subject: Reply with quote
there you go just don't break the gear, they are a pain to find replacements for.
First car!
ronjeds
PostPosted: Sat May 13, 2017 7:30 am    Post subject: Reply with quote
Ozzie - I recently had the same red odometer gear shift inward and not make contact with the gear driving the odometer/trip odometer counters. The red gear was not actually loose on the shaft. Over time the entire shaft had shifted inward causing the red gear to disengage with the counter gear. I simply used a small flat-tip screwdriver to shift the red gear and shaft outward until the red gear lined up exactly over the middle of the counter gear. Everything works fine now.
Many years ago I had the same problem with a previously owned 924S. That time the red gear actually was a bit loose on the shaft. I slid the gear off of the shaft, put a tiny dab of glue in the center hole of the gear and slid it back onto the shaft aligned exactly over the middle of the counter gear. I let the glue dry overnight and everything worked fine for several years until I sold that car.
Ron
1988 924S Special Edition
Ozzie
PostPosted: Sat May 13, 2017 8:13 am    Post subject: Reply with quote
I put a small spacer behind the red gear to stop moving in last time.
I will know more when I get it apart next time. (got bigger problems with freeze plugs ATM)
jvandyke
PostPosted: Tue Jan 08, 2019 3:16 am    Post subject: Reply with quote
Old thread I know but a "classic" issue.
I too had the whole odometer gear and shaft shift away from the worm gear, I too just pushed it back and it works fine (on the bench with an old cable and drill to power it).
I thought about a spacer but didn't do it. Should I? The speedo is still out on the bench (awaiting new LED bulbs for all the gauges).
The question: pull it apart to play with spacer option or not? Why did it shift out of position in the first place? Because somebody pushed the trip meter reset while in motion? I can avoid that, knowing better, if that was the cause? or does the whole thing "walk" out of position over time?
I think I'll leave it alone pending input.
87 924S project, '83 944 engine,
my son's first car.
jacobroufa
PostPosted: Tue Jan 08, 2019 3:21 am    Post subject: Reply with quote
I've been avoiding re-opening my speedometer. I replaced my gear this past summer with a new one as per instructions, but I did *not* put a dab of glue on it. I was told that press fit should be good enough. Unfortunately this meant for me that the new gear slipped within about 30 miles.
Pain in the butt.
If you ask me, I could have just re-secured the old gear with some glue and been done with it.
I will be cracking it open in the upcoming months and using a dab of super glue. Hopefully it stays this time. The real annoying part though in my opinion is trying not to muck up the trim ring that holds on the clear front of the speedometer...
jvandyke
PostPosted: Tue Jan 08, 2019 3:50 am    Post subject: Reply with quote
Yes, it was fun to uncrimp that thing. I could not get any tool under the "seam" for love or money. I finally took a cut off wheel via my dremel and sliced the back side to provide a place to start, that worked great was easy to do then though not very "tidy" it doesn't show when done so no big deal.
I was expecting to find the gear broken and had to head scratch a bit before I realized the whole shaft/gear and shifted, even then it wasn't until I used a drill to spin it up that I verified it actually worked again (spinning by hand is too slow to show up on the odo, it "looked like" it wasn't actually working).
So in my case the gear is holding okay to the shaft but the whole shaft is shifting. I probably should open it back up and put a spacer behind it to keep it from happening again.
If you skip to the 5:19 point in the vid below you can see that shaft is out of alignment too but he either didn't notice or think it's an issue, he pinned the gear back on the shaft but what if (as in our cases) the whole shaft moves? spacer. I think I'll go back in and add one, maybe just cut down the case of on ink pen or something easy
https://www.youtube.com/watch?v=aIGVe96yzN4
my son's first car.
Page 2 of 2
