Best way to repair rust holes
mikeycrum14
PostPosted: Thu Mar 09, 2017 3:00 am    Post subject: Best way to repair rust holes Reply with quote
I need to repair two rust holes on my 924. one is behind the passenger front tire on the side panel. (PO jacked up on pinch weld and broke through). the other is behind the rear passenger tire on the fender edge by the tire. it is small but annoying. What should i use to repair the panel? Fiberglass?
1981 924 - Alpine White
First car!
Fresh tune up, stage 3 racing clutch, stock otherwise, 5 speed trans. - SOLD
snakoil
PostPosted: Thu Mar 09, 2017 10:03 pm    Post subject: Reply with quote
for the rear I think a great option would be to put CGT rear flares
For real I would bring the car to a frame /welder professionnal for the front damage
For the rear I would try with self adhesive body patch from the inside and then bondo on the outside
1979 924 NA
mikeycrum14
PostPosted: Fri Mar 10, 2017 12:20 am    Post subject: Reply with quote
the front is just broken through the body panel. will the body patch work with an edge rust hole. like a bite mark out of the inside fender.[/img]
First car!
