Posted: Thu Mar 24, 2016 1:33 am Post subject: |
morghen wrote: | PRICELESS !!!
Good to have you on this board brother !
Rasta Monsta wrote: | WEASEL149 wrote: | ...and become a plenum inlet diffuser:-
Set to 'blow' versus 'suck'
_________________ 1980 931 - forged pistons, Piper cam, K27/26 3257 6.10 hybrid turbo, 951 FMIC, custom intake, Mittelmotor dizzy & cam pulley, H&S exhaust, GAZ Gold, Fuch'ed, Quaife
Posted: Thu Mar 24, 2016 3:00 am Post subject: |
Carrera RSR wrote: | Set to 'blow' versus 'suck' |
Posted: Thu Mar 24, 2016 3:55 am Post subject: |
_________________ Stefan
WEASEL149
Posted: Tue Mar 29, 2016 7:29 am Post subject: |
Spaceballs - awesome film _________________ 1979 UK 932 |
WEASEL149
Posted: Tue Mar 29, 2016 7:42 am Post subject: |
The 'Hoover' welded pretty good for a cast piece:-
Diffuser slot cut and just needs smoothing/blending:-
Chargecooler fitting underway - making an aluminium cradle:-
Chargecooler roughly in place:-
The small alternator in the pics is a 70A Denso weighing 2.8kg.
I have to check engine movement when it's fired up and may need to slot the charge cooler cradle fitting attached to the alternator bracket.
Hopefully this is enough pics to keep you guys happy.
I'm now trying to work out which way to go with the engine coolant radiators and the charge cooler radiator.
I think I'm going to make the badge panel removable as others have done. _________________ 1979 UK 932 |
Posted: Tue Mar 29, 2016 9:05 am Post subject: |
Damn outstanding. _________________ 1979 porsche 924 Na
Have u ever driven a turbo. |
Posted: Tue Mar 29, 2016 5:11 pm Post subject: |
this is going to be one fast 924 _________________ https://www.the924.com |
WEASEL149
Posted: Sun Feb 26, 2017 10:13 am Post subject: |
Update...
New charge cooler rad/heat exchanger:-
Chosen for large surface area but only ~17mm thick so it won't block airflow to the main rads. _________________ 1979 UK 932 |
WEASEL149
Posted: Sun Feb 26, 2017 10:15 am Post subject: |
Pic of new engine cooling rad. Two of these to cool head and block:-
WEASEL149
Posted: Sun Feb 26, 2017 10:18 am Post subject: |
Pics of new cooling cradle arrangement:-
WEASEL149
Posted: Sun Feb 26, 2017 10:24 am Post subject: |
Cooling assembly fitted to car:-
WEASEL149
Posted: Sun Feb 26, 2017 10:28 am Post subject: |
3" exhaust now complete:-
WEASEL149
Posted: Sun Feb 26, 2017 10:31 am Post subject: |
You want more, ok...
New cross member for the electric water pumps:-
WEASEL149
Posted: Sun Feb 26, 2017 10:33 am Post subject: |
Work underway to complete the inlet manifold and throttle:-
WEASEL149
Posted: Sun Feb 26, 2017 10:35 am Post subject: |
New vacuum manifold and used Bosch charge cooler pump - this may not get used as I've come up with a better alternative:-
