quest for accurate temp gauge
jvandyke
PostPosted: Sun Feb 19, 2017 1:06 am    Post subject: quest for accurate temp gauge Reply with quote
Situation;
83 944 engine in an '87 924s
currently temp gauge rises slightly and stays there, just a little off stone cold
The temperature gauge sender is different (small button style in '83 block with no "probe" vs. a single spade larger thread sender the 924s gauge wants; with a probe) with different resistance values no doubt.
Possible solutions;
1) drill and tap the block to accept the larger 924s sender
2) swap the gauge in the dash; either the whole temp/fuel/idiot light nacelle or just the temp part, no idea how they hook up or how interchangeable they are.
Thoughts?
87 924S project, '83 944 engine,
my son's first car.
TJC
PostPosted: Sun Feb 19, 2017 1:28 am    Post subject: Reply with quote
If you're not a stickler for originality you could fabricate a piece of tubing with a proper threaded boss welded into it to fit the sender you require for your present gauge which then splices into a coolant hose and there you have it. Easy peasy, and you don't need to mess with the block or the dash...used to do this on the race cars all of the time.
Edit!
Oh I almost forgot since I'm old and we used to use mechanical gauges mostly...you may need to make a provision for a ground wire connection by welding/brazing an electrical spade on your tubing or use some other method of grounding the sender.
'95 BMW 318i/5 "Pearl"
'86 Porsche 944 Turbo...Parting, Not Much Left!
'87 Porsche 944 NA "Liebchen"
Still on the Prowl!
www.ttrs1.com
PostPosted: Sun Feb 19, 2017 1:48 am    Post subject: Reply with quote
You should have no trouble just swapping the entire multi-gauge unit to an early white-lettered 944 gauge.
PostPosted: Fri Mar 03, 2017 10:49 pm    Post subject: Reply with quote
1983 track car, have both stock and aftermarket.
jvandyke
PostPosted: Wed Apr 26, 2017 12:13 pm    Post subject: Reply with quote
after much fiddling about and chasing grounds and all sorts of silliness, I just put a new sender on, all good. Duh.
my son's first car.
