Broken timing belt
ZacharyM
PostPosted: Fri Feb 17, 2017 5:18 pm    Post subject: Broken timing belt Reply with quote
Hello guys, I have a 88 924s that had a snapped timing belt while driving. As an interference engine, I worry of bent valves And a ton of money going to be spent (BTW my dad did it not my fault). Since I have not yet looked under the valve cover to actually inspect the damage, I'm looking for advice and help.
What could be broken and needs replacing without looking first?
What would you do.
And to inspect, can I leave the engine in or do I have to take it out.
Tia any constructive help appreciated.
PostPosted: Fri Feb 17, 2017 11:50 pm    Post subject: Reply with quote
Sorry for your loss.
Bent valves, possibly damaged pistons and rod bearings.
No need to remove the motor, used heads are cheap and are usually all that needs to be replaced.
In regards to blaming your dad, which one of you is responsible for properly maintaining the car? When was a front of engine service done last?
ZacharyM
PostPosted: Sat Feb 18, 2017 12:02 am    Post subject: Broken timing belt Reply with quote
Thank you for the response! It's his car that we barely used because 80% of it being in our position has not run. I just got into cars so I know understand the importance of car maintenance. The belt broke around December of 2014 and I plan on trying to fix her up.
PostPosted: Sat Feb 18, 2017 12:53 am    Post subject: Reply with quote
Some examples:
http://www.ebay.com/itm/Porsche-924S-944-Complete-Cylinder-Head-1985-5-1988/222390063757?_trksid=p2047675.c100623.m-1&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D41404%26meid%3D4f94cb46c1b449458ad072d8affa4720%26pid%3D100623%26rk%3D4%26rkt%3D6%26sd%3D322395374080
ZacharyM
PostPosted: Sat Feb 18, 2017 2:37 am    Post subject: Broken timing belt Reply with quote
Oh wow! That'd be great if that's all it'd need. Thank you
PostPosted: Sat Feb 18, 2017 3:18 am    Post subject: Reply with quote
You will also need at least:
All belts (4)
All tensioners and pulleys
Camshaft and balance shaft seals
water pump?
head gasket set
Antifreeze
Machine work?
ZacharyM
PostPosted: Sat Feb 18, 2017 3:20 am    Post subject: Reply with quote
Naturally! I have a timing belt kit that comes with a tension, pump etc. But I'll look into the others also, I'll probably inspect the engine within the couple days to see the real deal
PostPosted: Sat Feb 18, 2017 4:24 am    Post subject: Reply with quote
Excellent shop manual here:
http://www.clarks-garage.com/
hdrider19
PostPosted: Wed Apr 05, 2017 8:42 am    Post subject: Reply with quote
Lots of great videos on YouTube. Being new to these cars you might not know but the 944s also had the 2.5 engine. Most 944 videos also cover the 924S.
87 924S
