Doug&Julie
Posted: Sat Jun 25, 2016 7:29 am Post subject: |
I started another thread with this link, but I guess I should add it here, huh?
http://petrolicious.com/is-the-924-carrera-gts-clubsport-the-ultimate-front-engined-porsche-driver-s-car
Short article, but some nice detail pics. _________________ Doug
Currently Between Porsches
PART OF MY SOUL: '86 911, '76 912E, '06 Cayman S, '90 911 C4, '74 911, '78 911 Targa, '01 Boxster, '70 911T, '99 Boxster, '72 911T, '88 911, '99 Boxster, '84 911 Turbo Look, '73 911 Targa, '88 944 |
Harm
Joined: 28 Feb 2008 Posts: 1361 Location: Washington DC area
Posted: Mon Dec 12, 2016 7:43 am Post subject: |
So which one is Dan's? _________________ 1979 924 NA race car
1982 924 Turbo almost a PoS
Harm
Posted: Mon Dec 12, 2016 7:54 am Post subject: Re: Ultimate 924 Carrera GT/GTS/GTR Thread |
Fifty50Plus wrote: | So which one is Dan's? |
Zero.
These have chassis number wpozzz93zbn71nnnnn
“To gain Homologation to Group 4 in 1982, the FIA decided that 50 cars had to be seen by the authenticating inspectors all together …and here they are.” _________________ Porsche 924 NA 1982 LY7A/A3A3 _ Greater driving pleasure never harmed anyone. |
Posted: Mon Dec 12, 2016 8:11 am Post subject: |
Yeah, those are the GTSs, not the run-of-the mill GT like mine! _________________ erstwhile owner of just about every 924 variant ever made |
Posted: Mon Dec 12, 2016 8:19 am Post subject: |
We wish one upon Dan or any one of us for that matter....edit: I will take run of the mill GT
Best article at explaining the difference is from 911 & Porsche World
Posted: Mon Feb 13, 2017 5:23 am Post subject: |
I'm thinking about trying to duplicate the method used for the GTS's upper airbox housing on my 931, but haven't been able to find a good look at the underside of the GTS top airbox housing to figure out what sealing method it used to seal the the top of the AFM..
I see that it is attached by 2 bolts through the top of the housing that thread into the steel strap on the top of the AFM that has the rubber overtravel protector thingie on it, but does it use some rubber in there to make a good seal? Or is the underside of the airbox made into a sort of taper fit with a rubber or what?
Is their a PET style diagram for the GTS intake anywhere out there so I could look into its design more closely, or pics of its underside exist anywhere?
Need to see the belly of the beast..
See the bolt holes in the steel strap..
Also check out the AFR adjustment screw mechanism on this GTS, it gives you an intermediate sealed wrench on a spring and keeps the air seal, as far as I know it's like an $80 option for the merc, mine has one just like it.. You could probably install one on others too..
Bolts through the top..
Actually, looking at them, I think my upper AFM housing is the exact same as the GTS, which means you could stick a CIS-E head right on a GTS easy and gain computer control of the differential chamber pressure blah blah blah same fuel line connection style too..
But anyway, about that airbox..
Anyone know of more detail on the GTS upper air filter housing?
Would you do it a different way?
Dealing with very little hood clearance.. 2" maybe from the top of the AFM opening.. _________________ 80 Turbo - Slightly Modified |
Posted: Mon Feb 13, 2017 6:41 am Post subject: |
Check the gts rally replica thread, should be some pics of the gts air box build there, otherwise ill add them. _________________ 1980 924 Turbo
Posted: Mon Feb 13, 2017 7:34 am Post subject: |
Cédric wrote: | Check the gts rally replica thread, should be some pics of the gts air box build there, otherwise ill add them. |
YES! Their is this pic..
http://www.924board.org/viewtopic.php?t=38562
So it does indeed seem to be a taper, but I imagine some sort of rubber goes in there too no?
Do you use the same size filter element itself in the GTS or is it different/bigger?
I would be pretty interested in more pics of that airbox build and about how it was done.. _________________ 80 Turbo - Slightly Modified |
Posted: Mon Feb 13, 2017 7:55 pm Post subject: |
Or just buy a new one ready to bolt on from Mittelmotor _________________ 1980 931 - forged pistons, Piper cam, K27/26 3257 6.10 hybrid turbo, 951 FMIC, custom intake, Mittelmotor dizzy & cam pulley, H&S exhaust, GAZ Gold, Fuch'ed, Quaife
GaZiK
Posted: Tue Oct 31, 2017 10:08 pm Post subject: |
Hi, at some time of my 'racing' experience I decided to purchase 944 GTR headlights in order to make my car lighter. It wasn't an easy task to pick right ones... During this time I've read a lot about 924 racing history. Inspired by 924 GTP LeMans I ended up with my own version of headlights.
You can find the result of my experiment at http://gtpheadlights.com
Sorry for the off topic.
[/img] |
Harm
Posted: Mon Jul 02, 2018 6:49 am Post subject: Re: Ultimate 924 Carrera GT/GTS/GTR Thread |
^barf _________________ Porsche 924 NA 1982 LY7A/A3A3 _ Greater driving pleasure never harmed anyone. |
Harm
Posted: Mon Jul 02, 2018 6:50 am Post subject: Re: Ultimate 924 Carrera GT/GTS/GTR Thread |
Lets _________________ Porsche 924 NA 1982 LY7A/A3A3 _ Greater driving pleasure never harmed anyone. |
Harm
Move _________________ Porsche 924 NA 1982 LY7A/A3A3 _ Greater driving pleasure never harmed anyone. |
Harm
On… _________________ Porsche 924 NA 1982 LY7A/A3A3 _ Greater driving pleasure never harmed anyone. |
