Cabin Heater issues
mikeycrum14
PostPosted: Tue Feb 07, 2017 4:59 am    Post subject: Cabin Heater issues Reply with quote
So,
Coolant is full and gets hot
Valve to allow hot coolant into the dash is open
heater core gets hot. i can feel it getting hot when i stick my hand through the dash vent hole.
BUT:
the air coming from the fan still blows cool and not hot.
ALSO:
i am missing the air mixing chamber and the air ducting in the dash. WTB?
1981 924 - Alpine White, First car! LSD. - SOLD
1992 Miata - Freaking Red
1987 300zx Turbo - Also White
1991 Miata - White field find
1987 924S - Alpine White, Offroader Build, possible future TDI swap
mikeycrum14
PostPosted: Tue Feb 07, 2017 7:41 am    Post subject: Reply with quote
any help period would be appreciated... and i am looking to buy many of the heater/AC duct pieces that are inside the dash. such as the mixing chamber
PostPosted: Tue Feb 07, 2017 8:22 am    Post subject: Reply with quote
If you are missing R2D2 I have one.
PostPosted: Tue Feb 07, 2017 3:26 pm    Post subject: Reply with quote
Center vents are always cold, heat only comes to feet and defrost.
mikeycrum14
PostPosted: Wed Feb 08, 2017 12:28 am    Post subject: Reply with quote
that would be helpful. and my defrost vents aren't opening well all of the metal cables were unhooked and I had to figure out where they go... I cannot get the face vent/floor vent/defrost air flow position switch to work. ideas? and the connecting rod for the two face vents (between face vent dampers on heater core/blower) is missing a clip to keep it on the drivers side damper. (the clip that holds the ring on the end of the connecting rod from popping up off the damper and not moving it)
mikeycrum14
PostPosted: Tue Mar 28, 2017 4:26 am    Post subject: Reply with quote
the heater wont turn off... ideas on how to fix?
