Newbie wants MORE POWER
PostPosted: Sat Feb 04, 2017 7:52 am    Post subject: Reply with quote
Head work is not cheap. My guy in Delevan WI has reasonable rates, but even then, a fully re-done head (valves, guides, re-worked seats, skim cut, and mild port and polish) is a $2K proposition. If you can get it cheaper than that, you're either lucky or the technician is a hack.
One of the big issues with our heads is that the valve guides are a unique size and NOBODY has the correct tooling to work on them. Only places that have specifically done a 924 2.0L head before will have the right tooling. My guy in Delevan had to make his before he could work on my head. Same thing happened to me in Detroit, where there's an engine builder on every corner.
mikeycrum14
PostPosted: Sat Feb 04, 2017 7:58 am    Post subject: Reply with quote
cant I just buy a new valve guide set and put them in?... I am trying to find a cheaper "more power" solution to my stock 924 base.
1981 924 - Alpine White, First car! LSD. - SOLD
1992 Miata - Freaking Red
1987 300zx Turbo - Also White
1991 Miata - White field find
1987 924S - Alpine White, Offroader Build, possible future TDI swap
PostPosted: Sat Feb 04, 2017 8:02 am    Post subject: Reply with quote
No. The valve guides are pressed into the head, and you need a special bit and chuck to press them out without damaging the soft aluminum head and ruining the guide bores for the new guides to follow.
mikeycrum14
PostPosted: Sat Feb 04, 2017 8:03 am    Post subject: Reply with quote
you have been super helpful, I don't think im ready to spend that kind of money on my first car right off the bat. what do you suggest as a cheaper way to go faster faster?
PostPosted: Sat Feb 04, 2017 8:04 am    Post subject: Reply with quote
1. Define cheap.
2. I already defined an $800 solution for you that will increase your HP by 15-20% (hot cam + Cometic gasket)
That's about as cheap as it gets with this motor. Unless you want to do Nitrous, which is not advisable on a motor of questionable provenance.
Noahs944
PostPosted: Sat Feb 04, 2017 8:39 am    Post subject: Reply with quote
buy a honda civic
PostPosted: Sat Feb 04, 2017 9:37 am    Post subject: Reply with quote
1. Define cheap.
That's a nice way to say nitrous is stupid.
Noahs944
PostPosted: Sat Feb 04, 2017 10:33 am    Post subject: Reply with quote
"stupid"?
Like the American aircraft engineers who integrated it into some expensive aircrafts that were depended upon to save lives in WW2?
Stupid, eh?
Effective... fast to assemble... sometimes inconvenient... potentially disastrous in the hands of people who don't research and take precautions, sure. Not stupid though.
PostPosted: Sat Feb 04, 2017 11:04 am    Post subject: Reply with quote
Noahs944 wrote:
"stupid"?
Stupid, eh?
As previously stated if you have a forged bottom end engine built to run nitrous in a drag racing environment it's fine. Otherwise it's stupid and creates tremendous wear on your engine.
PostPosted: Sat Feb 04, 2017 11:25 am    Post subject: Reply with quote
There are other applications for Nitrous.
You might like what I'm cooking up for DUSTY. Bwahahaha.
PostPosted: Sat Feb 04, 2017 11:39 am    Post subject: Reply with quote
What I like about Dusty is the wheels. I want those on my car.
Noahs944
PostPosted: Sat Feb 04, 2017 12:13 pm    Post subject: Reply with quote
If the 924 n/a can't handle 35 horsepower of boost in stock form... well, that says a lot about the quality of components these cars are made of... since just about every other car on the planet could handle it.
Nicky, I'm walking away from this conversation because I don't feel like I have someone competent enough to spar with (based on your previous arguments). A bit disappointing.
PostPosted: Sat Feb 04, 2017 12:25 pm    Post subject: Reply with quote
My machinist threads the inside of the guides and pulls them out without any damage on all the different Porsche heads I give him. Problem with the NA 924 is that they don't breath well regardless of guide size.
1979 924 NA race car
1982 924 Turbo almost a PoS
PostPosted: Sat Feb 04, 2017 12:30 pm    Post subject: Reply with quote
Yeah, but how does he put the new ones back in? Gotta have a special bit for that.
PostPosted: Sat Feb 04, 2017 1:12 pm    Post subject: Reply with quote
The guy that wants to put headers sticking out the top of his hood calling someone a mental midget. That's laughable.
Page 2 of 4
