Wastegate valve guide play
PostPosted: Fri Jan 27, 2017 6:59 am    Post subject: Wastegate valve guide play Reply with quote
How much play may a wastegate valve guide have ?
I asume it can have more play then a valveguide of the cilinder head because in the wastegate it is not oil cooled/ lubricated.
Can you buy a new valve guide somewhere?
937 DITC
PostPosted: Fri Jan 27, 2017 8:37 am    Post subject: Re: Wastegate valve guide play Reply with quote
Good question
Not that I've found
If you take the wastegate apart, be aware that the big fiber gasket between the upper and lower housings is not available anywhere and you'll need to make your own.
gegge
PostPosted: Fri Jan 27, 2017 9:34 pm    Post subject: Reply with quote
I hade one with several millimeters of play. Good from a heat expansion point of view, it certainly didn´t stuck. But longlivety of the membrane suffered.
The WG valve is slow moving compared to the valvetrain , no risk of wear or seat damage due to misalignment from valveguide wear.
Carl Fredrik Torkildsen
PostPosted: Sat Jan 28, 2017 12:22 am    Post subject: Re: Wastegate valve guide play Reply with quote
I assume it can have more play then a valve guide of the cylinder head because in the wastegate it is not oil cooled/ lubricated.
If you can't get one anywhere maybe I can make them. I have made valve guides before (reliably saw 11000+k in a ducati) and I am currently doing it now on a 931 head
I'll see if I can find my disassembled wastegate today (the one where the previous owner used high temp silicon to repair the diaphragm )
1980 931 ...off with the cobwebs
1979 924 NA M471/M481 ohne M650 Herausnehmbares Dach
0.5 1982 931 smashed parts car
1982 931 parts car?
PostPosted: Sat Jan 28, 2017 2:55 am    Post subject: Reply with quote
I never found a spec, but mine was quite loose as well. Head rebuilder fabbed a guide.
PostPosted: Sat Jan 28, 2017 3:18 am    Post subject: Re: Wastegate valve guide play Reply with quote
I would love to be able to offer these as part of my rebuild kit. What do we need to do to make this happen?
PostPosted: Sat Jan 28, 2017 4:33 am    Post subject: Reply with quote
Take that back, looked back at an old thread and apparently spec is .003?
PostPosted: Sat Jan 28, 2017 4:55 am    Post subject: Re: Wastegate valve guide play Reply with quote
I'll measure everything and make one up. It would be nice to measure it before and after install so we know how the install tightens things up. Once we are all satisfied, it should be good to go.
Here is a manganese bronze valve guide I made up for a Ducati
1982 931 parts car?
PostPosted: Sat Jan 28, 2017 5:13 am    Post subject: Reply with quote
Found it...although I wish I would keep things together for the sake of organization
1982 931 parts car?
PostPosted: Sat Jan 28, 2017 5:21 am    Post subject: Reply with quote
Mike, I have countless spare wastegates. Are you coming to Fourth Friday this afternoon? You can take one or two back with you for dissection and experimentation.
PostPosted: Sat Jan 28, 2017 5:38 am    Post subject: Reply with quote
Forth Friday? I am missing something
1982 931 parts car?
PostPosted: Sat Jan 28, 2017 7:24 am    Post subject: Reply with quote
https://www.facebook.com/events/209593959503427/
Sorry, thought you were on the invite list...all day today, whenever you can arrive until 9 or maybe later
PostPosted: Sat Jan 28, 2017 8:00 am    Post subject: Reply with quote
Oh thats cool
I have a cold that settled in yesterday kicking my butt but this is good to know
1982 931 parts car?
PostPosted: Sat Jan 28, 2017 1:55 pm    Post subject: Reply with quote
Awkward!
PostPosted: Sun Jan 29, 2017 7:18 am    Post subject: Reply with quote
Awkward!
Not really I am on facebook only by proxy and I wasn't updated. I check every now and then and simply missed it.
I knew Dan wanted to do this but I figured in the Spring. He started early and I like the idea
1982 931 parts car?
