Making a test setup for the K-jetronic fuel system
PostPosted: Sun Jan 15, 2017 8:07 am    Post subject: Making a test setup for the K-jetronic fuel system Reply with quote
I making a test setup so I can adjust/ equal the flow to the injectors.
I have a Bosch pressure gauge which I have to fit, but I have to make an adapter for it first.
I also want to add a wire to the wur so it can warm up
When pushing the meteringhead plate down, it works for a few seconds but then it stops spraying fuel, what am I doing wrong ?
937 DITC
PostPosted: Mon Jan 16, 2017 3:41 am    Post subject: Re: Making a test setup for the K-jetronic fuel system Reply with quote
I could see that happening if you were just spraying off the rest of your residual pressure but I think that's unlikely since your FP is right there with wires on it..
You do have your FP running full time and your return to tank lines are constantly flowing correct?
PostPosted: Mon Jan 16, 2017 5:10 am    Post subject: Reply with quote
Fuel pump is constant running and got a return line bak into a smalltank
maybe the fuelpump is bad, have to hook up the pressure tester first
937 DITC
PostPosted: Tue Jan 24, 2017 6:51 pm    Post subject: Reply with quote
hooked up the pressure gauge, the pressure drops when you put down the plate in the air flow meter.
Could this be because I don't have the accumulator in the set-up ?
937 DITC
PostPosted: Wed Jan 25, 2017 2:24 am    Post subject: Reply with quote
Is the pump gravity fed? Accumulator shouldn't effect volume.
PostPosted: Wed Jan 25, 2017 5:56 am    Post subject: Reply with quote
I could see the accumulator helping dampen pressure spikes and dips but it should have no effect on overall flow..
You can do a FP flow test as per the manual..
Maybe it could be the system pressure regulator in your FD sticking if not the pump? The plunger thing on the side, you can take it apart and clean it but be extra very areful with the plunger and its bore so you do not scratch it even the tiniest amount, precision surfaces etc..
You say the pressure drops right? How?
Does it just dip a little bit and come right back up?
Does it drop down to a lower pressure and stay steady while the injectors run?
Does it just drop to zero 0 ?
Did this system work ok before you put it into this test setup?
Is it possible you have your main feed and tank return lines backwards?
PostPosted: Wed Jan 25, 2017 7:22 am    Post subject: Reply with quote
pump is not gravity fed, could this be a problem ?
Eddy, I have to check again to give you an answer
Is this correct ?
1- fuel pump fed
2- WÚR out
3- fuel return
4- cold start valve
5- Wur in (large hole)
6- injector 1
7- injector 2
8- injector 4
9- injector 3
937 DITC
Last edited by Dutch924-racer on Wed Jan 25, 2017 7:43 am; edited 2 times in total
PostPosted: Wed Jan 25, 2017 7:35 am    Post subject: Reply with quote
PostPosted: Wed Jan 25, 2017 7:46 am    Post subject: Reply with quote
I got the order of the injectors wrong, but thet shouldn't be a problem I assume ?
937 DITC
PostPosted: Wed Jan 25, 2017 9:09 am    Post subject: Reply with quote
Doesn't matter on a continuous injection system
PostPosted: Wed Jan 25, 2017 1:50 pm    Post subject: Reply with quote
yup
