BTRacing
Joined: 31 May 2014 Posts: 434 Location: Nortbrook,IL
Posted: Thu Jan 05, 2017 1:44 pm Post subject: |
Thank you !
Roof panel will be replaced with no sunroof fiberglass panel.
Tip: make sure that your tube notching is very tight.
Spend the time to fit them as close as possible. It takes a while but it is easier to fill the gap and will give you stronger joint.
Make sure that your heat is set right,practice on the scrap piece of tubing to set the welder right.
Take your time.... Cage is your safety. _________________ www.btr-chicago.com
1977 924 Martini
1979 931 GTR Le Mans replica to be
1993 Mercedes 190E Sportline LE, one of 700 made
2020 Ford F350 Tremor daily driver/tow pig
1974 Moto Guzzi Cafe Racer
2002 Formula Fastech 382 |
Joined: 10 Dec 2006 Posts: 946 Location: Noosa Heads QLD Australia
Posted: Thu Jan 05, 2017 11:14 pm Post subject: |
Such a nice job.......with beautiful welds. Bravo! _________________ 80/81 932/8 ROW |
Joined: 23 Jul 2007 Posts: 1076 Location: The Netherlands
Posted: Fri Jan 06, 2017 4:30 am Post subject: |
great project!
Do you have more info/ pictures on the sunroof delete conversion ? _________________ 937 trackday car
Posted: Fri Jan 06, 2017 5:17 am Post subject: |
peterld wrote: | Such a nice job.......with beautiful welds. Bravo! |
+1 one on that
tigging a cage, nice!! ...and your fitment of the tubes also very nice _________________ 1980 931 since 1989
Posted: Fri Jan 06, 2017 4:06 pm Post subject: |
Think I spy a late rad support in there... _________________ Toofah King Bad
BTRacing
Posted: Fri Jan 06, 2017 11:40 pm Post subject: |
Yes it is late model radiator support. First idea was to run 944T intercooler with GTS intake, but I think I want to build a larger ,custom intercooler that would look closer to original. _________________ www.btr-chicago.com
1977 924 Martini
BTRacing
Posted: Sat Jan 07, 2017 1:03 pm Post subject: |
Just got my fiberglass roof panel. Pretty good quality. I will post some fitment pictures next week. _________________ www.btr-chicago.com
1977 924 Martini
Posted: Sat Jan 07, 2017 4:44 pm Post subject: |
Do you have a picture of the front of the roof above the windscreen ?
Where did you cut is the roof in the front ?
thanks! _________________ 937 trackday car
BTRacing
Posted: Sun Jan 08, 2017 7:59 am Post subject: |
Some of you asked about pictures of roof removed ,here they are
1977 924 Martini
BTRacing
Posted: Sun Jan 08, 2017 8:01 am Post subject: |
1977 924 Martini
Posted: Sun Jan 08, 2017 5:34 pm Post subject: |
Great, many thans!
How much work was it, you did it all with point drill, and only cut the 'a' pillar? _________________ 937 trackday car
Posted: Sun Jan 08, 2017 6:48 pm Post subject: |
Dutch924-racer wrote: | Great, many thans!
How much work was it, you did it all with point drill, and only cut the 'a' pillar? |
No cut at the a pillar. Just a 'join'. Grind back to expose spot welds and joins. _________________ 1980 931 - forged pistons, Piper cam, K27/26 3257 6.10 hybrid turbo, 951 FMIC, custom intake, Mittelmotor dizzy & cam pulley, H&S exhaust, GAZ Gold, Fuch'ed, Quaife
BTRacing
Posted: Tue Nov 24, 2020 9:04 am Post subject: |
1977 924 Martini
BTRacing
Posted: Tue Nov 24, 2020 9:05 am Post subject: |
1977 924 Martini
BTRacing
1977 924 Martini
