gauge coolant sensor differences
jvandyke
PostPosted: Wed Dec 07, 2016 2:24 am    Post subject: gauge coolant sensor differences Reply with quote
car: '87 924s
engine; '83 944
temp gauge on dash always suspect, tended to read low, now inop.
When looking at sensors I see a difference between that listed for an '87 and those listed for an '83 2.5 from a 944.
What's the difference?
I'm not sure which part to go after for an accurate gauge reading.
The both "look" like this
87 924S project, '83 944 engine,
my son's first car.
PostPosted: Wed Dec 07, 2016 2:36 am    Post subject: Reply with quote
Your engine is from an '84 944? Not sure on the differences, but, I'd go with the '87 924S part, to match the gauge.
PostPosted: Wed Dec 07, 2016 2:51 am    Post subject: Reply with quote
More likely a ground problem than the sender.
jvandyke
PostPosted: Wed Dec 07, 2016 4:48 am    Post subject: Reply with quote
I will go after grounds for the gauges then, first. Is there a good electric diagram floating around, this is all I can find, I have the 944 Haynes but that doesn't do me much good for body stuff.
http://www.pelicanparts.com/944/electrical/944_electrical_diagrams.htm
my son's first car.
PostPosted: Thu Dec 08, 2016 12:05 am    Post subject: Reply with quote
The main ground is up above, can't reach, spot under the windshield area, driver side. Looks like pop bottle tops upside down~! There are blade connections there, and they get corroded. If you remove the dash, much better access.
Timmay!
PostPosted: Sun Jan 29, 2017 1:03 am    Post subject: Reply with quote
Yes, 2 different sensors. Early has 1 contact for the gauge needle and the base is small diameter (doesn't penetrate water jacket in block) . Late has 2 contacts, one for the needle, one for the idiot light? , base is bigger and it sticks into the water inside the block.
Current project 1981 931
944 spec # 22 924S
77 924 Martini. Rescued. Sold
88 924S SE. Rescued. Sold
PCA since 1985
edredas
PostPosted: Sun Jan 29, 2017 6:21 am    Post subject: Reply with quote
Early 944 sensor
924S Sensor with single blade
Late 944 sensor with two blades. One for temp other for idiot light
I hope that helps!
'84 944 -White, Brown interior
'84 944 -Red, Automatic
'87 924S -Red, 300hp 951 swap
'87 924S -Red, Project Car
'88 924S -Red, Daily Driver
jvandyke
PostPosted: Tue Feb 14, 2017 5:49 am    Post subject: Reply with quote
Thanks for that!!
Pretty sure we've got the first one pictured: the "button" single contact style.
Probably should have the 924s style to match the gauge, that would be the first thing to do.
BTW the gauge is "working" comes off stone cold and get's to about 1/4 and stays so likely it's just the wrong sensor/gauge combo.
Looks like the middle one is rare, Pelican doesn't show it, cheapest I've found is $80, ouch.
Wonder if one made for the VDO (non oem, right?) is the same resistance?
http://www.autoatlanta.com/results.php?partnumber2=Porsche%20Boxster%20Water%20Temp&narrowcar=924%201986-88&narrowsection=Electrical
Wonder if one of you guys has a used one?
my son's first car.
PostPosted: Tue Feb 14, 2017 1:05 pm    Post subject: Reply with quote
I'll look in the morning, don't buy anything from AA.
jvandyke
PostPosted: Tue Feb 14, 2017 11:25 pm    Post subject: Reply with quote
I hear you about AA. Not happening. Been there.
my son's first car.
PostPosted: Wed Feb 15, 2017 4:05 am    Post subject: Reply with quote
I have one. Email sent.
[img][/img]
jvandyke
PostPosted: Sat Feb 18, 2017 8:57 am    Post subject: Reply with quote
I assumed they were interchangeable, nope. early 944 "button" style smaller, can't put the 924s sensor (nor presummably the later 944 double spade) into the early 944 block. will have to either re-thread the block or get a different gauge. I'm trying to figure out how the early 944 and '87 924s temp gauge compare, maybe (since I think each gauge is individually mounted?) I can swap out just the temp gauge?
my son's first car.
PostPosted: Sat Feb 18, 2017 1:17 pm    Post subject: Reply with quote
What color are your gauges? I may have one.
PostPosted: Sat Feb 18, 2017 1:22 pm    Post subject: Reply with quote
Email sent.
edredas
PostPosted: Sat Feb 18, 2017 7:07 pm    Post subject: Reply with quote
Ah, I thought they would be interchangeable too... I seldom come across a very early block so keeping track of everything is difficult. I have two "early" blocks, or at least what I consider them early since they have the 3-piece oprv and eccentric tensioner, but use the late temp sensor so I wasn't aware the size changed.
