ks114
Posted: Sat Nov 26, 2016 5:41 am Post subject: New guy needs help! |
Hi, This is my 2nd post here. Hope you can help. I just bought a 1981 924 with a Weber conversion. The problem is the vacuum advance isn't hooked up.
What port on the carb does it hook to? I Ve got pics of the carbs/manifolds if it helps. Thanks,Steve |
Posted: Sat Nov 26, 2016 7:06 am Post subject: |
Vacuum advance goes below the throttle plate. _________________ 1979 924 NA race car H-Prod SCCA
1981 924 Turbo sold
1982 924 Turbo sold
ks114
Posted: Sat Nov 26, 2016 7:15 am Post subject: |
| Is there a port there that I can put a fitting in? |
The craig
Joined: 13 Nov 2015 Posts: 8 Location: Brisbane Australia
Posted: Sat Nov 26, 2016 7:36 am Post subject: |
There are a few different thougts on this some people take directly off the manifold others go for ported and multiple carbs make it more fun
I would go of the ported vac on the carbs and tee both ports together and to the dizzy _________________ 5 cars
two car garage
Somthings got to give |
ks114
Posted: Sat Nov 26, 2016 8:59 am Post subject: |
| Are the fittings for the vacuum ports readily available at the parts store, or is this a Weber specific part? |
Posted: Sun Nov 27, 2016 12:21 am Post subject: |
I have a completely different setup because I'm at 8000', but the Redline folks had me plug/cap and not use the vacuum advance, go to a zero bypass on the accelerator pump jet(I think that is the right term) and set the ignition advance to about 15 degrees BTDC. At least 5 degrees of that is for altitude. _________________ Mike
'67 MG Midget Dp
muffin787
Posted: Mon Dec 05, 2016 1:19 am Post subject: vacum advance |
I convert my 1980 924 to webber many years ago. I don't use the vacum advance. if you have two side draft, you will notice a pulse vacum. It make very difficult or impossible to set the advance. You will only have to work with the mechanical(centrifugal) advance. _________________ Porsche 924 1980, 944 brakes, GM alternator, GM Master Cylinder, 40decoe weber, Crane ignition module. |
Posted: Mon Dec 05, 2016 4:43 am Post subject: |
Path of least resistance is to have your distributor recurved for straight mechanical advance. There are many specialists who can readily do this.
Next choice is Ignition 123. _________________ Toofah King Bad
