F@#k....need an engine rebuild?
dreygata
PostPosted: Tue Nov 08, 2016 11:05 am    Post subject: F@#k....need an engine rebuild? Reply with quote
Well this hasn't been the best of weekends. On top of some currently un-resolvable issues with a couple motorcycle projects, and my phone taking a really bad fall, my 924S developed an engine knock.
After draining the oil, I stuck one of those extendable magnets into the oil pan's drain hole, and pulled out a few metal pieces.
I haven't fully sifted through the oil (which is currently in a couple of perfectly clean plastic shoe boxes), but I'm guessing that my rod bearings are shot.
Not sure what caused it, as the oil level seemed to be within spec, but given that I've had this car maybe one month, who knows.
I'm guessing that I'll be needing to do an engine rebuild unless you guys think something else would work.
An engine rebuild will be the most extensive thing I've taken on, but I've rebuilt a basket case motorcycle so hopefully it's not horribly more difficult.
'87 Porsche 924S
PostPosted: Wed Nov 09, 2016 2:13 pm    Post subject: Reply with quote
Time for a SBC
87 924s
88 924SE gone
447 hp cgt clone
87 924S gone
84 944 sold
83 944 sold
89 turbo S LSD, ABS etc
86 951 white rocket
85 944 sport everything.
84 944 sold.
87 944 sold
dreygata
PostPosted: Thu Nov 10, 2016 10:12 am    Post subject: Reply with quote
SBC? (sorry I'm new)
'87 Porsche 924S
PostPosted: Thu Nov 10, 2016 1:12 pm    Post subject: Reply with quote
Small Block Chevy.
87 924s
88 924SE gone
447 hp cgt clone
87 924S gone
84 944 sold
83 944 sold
86 951 white rocket
84 944 sold.
87 944 sold
hdrider19
PostPosted: Thu Nov 10, 2016 1:30 pm    Post subject: Reply with quote
I bought my car as a non-runner. Picked up a running 84 944 parts car for$700. I took apart the 2.5 to fix all the oil leaks and clean everything. They aren't that hard to work on but do require a few special tools. I bought full gasket/seal kit, timing belt set and water pump. I have rebuilt many car engines and the 2.5 is not terrible to work on. BTW this is my first porsche too.
87 924S
edredas
PostPosted: Fri Nov 11, 2016 6:07 am    Post subject: Reply with quote
I believe that if you can work on motorcycles then you should have no problem working on these. They're just regular old four cylinders...
'84 944 -White, Brown interior
'84 944 -Red, Automatic
'87 924S -Red, 300hp 951 swap
'87 924S -Red, Project Car
'88 924S -Red, Daily Driver
dreygata
PostPosted: Fri Nov 11, 2016 7:06 am    Post subject: Reply with quote
Very true, though the mass of it makes it more daunting. Removing an engine from a bike is a bit simpler than a car.
'87 Porsche 924S
PostPosted: Sun Nov 13, 2016 10:21 pm    Post subject: Reply with quote
Have you established what actually happened?
87 924s
88 924SE gone
447 hp cgt clone
87 924S gone
84 944 sold
83 944 sold
86 951 white rocket
84 944 sold.
87 944 sold
dreygata
PostPosted: Tue Nov 15, 2016 2:13 am    Post subject: Reply with quote
I have not yet. Had to be out of town (plus work, plus school...) so I haven't touched it.
I plan on working on it this weekend. I'm a bit fearful of putting new oil in and running the car, but I got to do what I got to do...
'87 Porsche 924S
dreygata
PostPosted: Tue Nov 15, 2016 2:15 am    Post subject: Reply with quote
Another board suggested a broken valve spring, since the material is magnetic. Plan is to fill with new oil, run the engine, listen for location, pull plug wires to see if the noise lessens.
I could also send off to have the oil analyzed
'87 Porsche 924S
PostPosted: Wed Nov 16, 2016 12:37 am    Post subject: Reply with quote
Have you checked oil pressure? If you have enough damage in the bottom end to cause rod knock oil pressure would be low.
87 924s
88 924SE gone
447 hp cgt clone
87 924S gone
84 944 sold
83 944 sold
86 951 white rocket
84 944 sold.
87 944 sold
PostPosted: Sat Nov 26, 2016 1:31 am    Post subject: Reply with quote
http://louisville.craigslist.org/pts/5885307795.html
87 924s
88 924SE gone
447 hp cgt clone
87 924S gone
84 944 sold
83 944 sold
86 951 white rocket
84 944 sold.
87 944 sold
