Gazc2
Posted: Wed Nov 09, 2016 7:53 am Post subject: Rev Counter not working |
Can anyone give me some pointers for testing the rev counter which is not working in my car .Does it take a signal from the coil (Green Wire?) which I suppose the only check is a continuity check ?. I have yet to remove the iinstruments yet so don't know the condition of the connections.
any help appreciated
Gaz |
edredas
Posted: Fri Nov 11, 2016 6:04 am Post subject: |
Yes, the green wire is the signal from the DME, and the black wire is the power. The power comes from the DME relay. There is a brown wire on the chassis of the tach and if it is not plugged in then the tach will not work.
I hope that helps! _________________ '84 944 -White, Brown interior
'84 944 -Red, Automatic
'87 924S -Red, 300hp 951 swap
'87 924S -Red, Project Car
'88 924S -Red, Daily Driver |
Gazc2
Posted: Fri Nov 11, 2016 6:14 am Post subject: |
Thank you sir very helpful, I have a new speedo to fit as well so hopefully will get this sorted at the same time.
cheers
Gaz |
