Khal
Joined: 26 Sep 2003 Posts: 4869 Location: Sunny and lovely interior BC, Canada
Posted: Sat Feb 20, 2010 6:14 am Post subject: |
Martijnus wrote: | The 924 engine doesn't really have special powers that any other engine doesn't... |
morghen, if you promise to chant the above mantra daily, then I promise I will chant the following;
Martijnus wrote: | ...it's fun to modify that base to the max |
_________________ '80 924 Turbo |
924OZY
Joined: 24 Jan 2010 Posts: 71 Location: Gold Coast Australia
Posted: Sat Feb 27, 2010 3:34 am Post subject: |
It was used at Le-Mans.
Thats a special power _________________ 924 N/A snailshell, superpro linkage bushes, 2.5"exhaust
4.0L ef Fairmont, 3000rpm stall, shift-kit, J3 chip, 3" exhaust, self tuned using tunerpro, soon to be boosted,
expecting 350Kw at wheels at 10psi. |
Khal
Posted: Sat Feb 27, 2010 4:56 am Post subject: |
924OZY wrote: | It was used at Le-Mans.
Thats a special power |
It lost. _________________ '80 924 Turbo |
Posted: Sat Feb 27, 2010 5:40 am Post subject: |
surviving means wining at lemans...the 924 has the special power of being very robust and forgiving...its a tank _________________ https://www.the924.com |
Paulyy
Posted: Sun Oct 02, 2016 5:05 pm Post subject: |
So no one found anything close enough even if it required modification to adapt a 16v engine on the 924 block? _________________ 924 - Race car project in the works.
951 - 400whp. |
gegge
