Oil....again
agfisher
PostPosted: Fri Oct 28, 2016 1:35 pm    Post subject: Oil....again Reply with quote
I see a lot of people are recommending Conventional 20W50 for NA 2.0s that are going to be summer driven. The issue I'm having though is what brand and where to find it.
I hear a lot of people say go with Mobil 1 but all I can find from them is 20W50 V-Twin Synth. I also see a Castrol GTX High Milage that sounds right but some people didn't think Castrol was that good (Again, this is just stuff I've been reading).
What oil are you guys finding and what weight are you using?
1977 924 N/A Martini Edition
Power Tryp
PostPosted: Fri Oct 28, 2016 2:24 pm    Post subject: Reply with quote
I use what Ideola sells because I know he's been successfully been using it in his own cars for quite some time now.
http://garage.ideola.com/prod-Supplies.html#motoroil
However, if I didn't have access to that i've been give the impression that some people use Shell Rotella T diesel oil with satisfactory results.
I'm sure Rasta will be here to give you his recommendation soon, he loves oil threads.
Melanie - 1980 931
Scrappy - 1980 924 shell
NoName - 1980 931 (seeking rebuild)
Green tartan interior, you don't see that on a Civic.
agfisher
PostPosted: Sat Oct 29, 2016 12:31 am    Post subject: Reply with quote
I see the Brad Penn is partially synthetic. Is that OK for a high mileage engine? Everything I've read says Dino only.
PostPosted: Sat Oct 29, 2016 1:00 am    Post subject: Reply with quote
Rasta's choice. High zinc, increased power and economy over 20w50.
  • Weisse (1987 924S) - Turbo S3
agfisher
PostPosted: Sat Oct 29, 2016 1:15 am    Post subject: Reply with quote
I see it's synthetic. That's not great for my old engine, correct?
Power Tryp
PostPosted: Sat Oct 29, 2016 1:19 am    Post subject: Reply with quote
What mileage are we talking about specifically? I'm guessing that you odometer has rolled over at least once so we're in the 100k range?
Melanie - 1980 931
agfisher
PostPosted: Sat Oct 29, 2016 1:22 am    Post subject: Reply with quote
One flip over, approx 35,000 so I'd say 135K. The car has been in my family since bought new in 77. No rebuild. Been sitting unused since 87-88. Now that my twins are older finally have time to start get this thing rolling.
PostPosted: Sat Oct 29, 2016 1:47 am    Post subject: Reply with quote
"Synthetic not good for old motors" is an old mechanic's tale, IMO.
Synth (especially high quality synth like LM) has properties that decelerate wear. The only arguable downside is that some synthetics have high detergent (just as some dino oils do), which can cause shaft seals to leak if the only thing holding a seal is deposits.
On a toofah, though, the positive crank venting is fairly aggressive, so you really shouldn't encounter a problem.
Kenodog
PostPosted: Sat Oct 29, 2016 2:05 am    Post subject: Reply with quote
Synthetic oil is also 'creepier' than dino oils. I put some in a new motorcycle and the next day had a pool under the bike. Had to pull the side cover off and use some Hylomar to reseal it. It was the same weight synthetic as dino but it has better wicking capabilities apparently meaning it may drip where dino oil will not.
Me
1979 Euro 931, Olive
1981 931, Sabine
2014 Mazda CX-5 (Kinderwagon)
2008 GS500
2016 DR650
2019 KTM 790 Adventure
Power Tryp
PostPosted: Sat Oct 29, 2016 2:27 am    Post subject: Reply with quote
Wow, that's impressive. Tbh, your biggest issue is going to be seals.
Personally on an engine that old with no rebuild I would want to re-seal it as that is where a synthetic would be you biggest problem as it tends to flow better across all temperature ranges and will most likely seep past the old rubber.
https://m.youtube.com/watch?v=Se8-W7rK0H4
https://m.youtube.com/watch?v=tYkg0oDUXs8
Those will clear up some of the misinformation on modern synthetics.
And there's a detailed writeup from a Corvair owner which leads us effectively to what Rasta has suggested.
http://www.widman.biz/Corvair/English/Links/Oil.html
Melanie - 1980 931
prophead
PostPosted: Sat Oct 29, 2016 6:42 am    Post subject: Reply with quote
Valvoline VR Racing 20w/50
924 GT "8 Ball" track car project
944 Lux rolling project, nearly done
PostPosted: Sat Oct 29, 2016 9:02 am    Post subject: Reply with quote
Switching oil to get more power... I did that. Started running 5 w 30 in a 924. Only problem was the oil would only fit in a corvette engine. Now the power is too high
87 924s
88 924SE gone
447 hp cgt clone
87 924S gone
84 944 sold
83 944 sold
89 turbo S LSD, ABS etc
86 951 white rocket
85 944 sport everything.
84 944 sold.
87 944 sold
PostPosted: Sat Oct 29, 2016 10:29 am    Post subject: Reply with quote
I bet that would be great in a 1.8t
Glemon
PostPosted: Sat Oct 29, 2016 11:19 pm    Post subject: Reply with quote
Lots of oil threads in the old British car world I have been in for a lot longer than the Porsche world, lots of opinions, but Valvoline VR1 (getting a little harder to find but may still be locally available) and Brad Penn generally get the nod for best oils for high zddp content to prevent cam lobe wear.
81 924 (gone, needs replaced)
68 TR250
02 IS300
PostPosted: Sat Oct 29, 2016 11:23 pm    Post subject: Reply with quote
I use Pennzoil dino 10w-40 year round and have for decades in my 924s. Why are we worried about cam wear, has anyone worn one out?
