Project black 924 :)
Goto page Previous  1, 2, 3, 4, 5, 6, 7
WEASEL149
PostPosted: Wed Sep 16, 2015 7:16 am    Post subject: Reply with quote
Raceboy wrote:
That was my guess. The rods are quite heavy and could not cope with the hugely increased tensile loads. I have never dared to rev the 924 engine past 7k on regular basis...
It begs the question then... if you want to rev up to 7500rpm with a hotter cam in a max effort turbo engine, is it worth buying ARP bolts for stock rods, or just buying new and lighter rods with their own corresponding ARP bolts?
This is the first time my faith in the stock rods has been shaken a little.
Maybe stock rods with full prep/shot peen lightened to 815g with ARP bolts would hold up better?
It's definitely rev related failure rather than boost. It's a diesel engine so designed for high compression...
1979 UK 932
DutchPug
PostPosted: Wed Sep 16, 2015 8:29 am    Post subject: Reply with quote
Yes could very well be rpm related. But at two bar it did not hold up long, just a few hundred km and have the rev limit since i have the cam. Perhaps just a coincidence. I do intend to shift just before the limiter basically everytime i floor it, meaning i took it to 7000 - 7200 rpm a lot. It's just too much fun
Think in any case it is not sensible running high rpm with the stock rods... but if the turbo comes on boost late... you want te stretch the power-band as much as possible.
Maybe some more clues appear when taking the engine apart.
Anybody know some off the shelve forged pistons for the NA?
WEASEL149
PostPosted: Wed Sep 16, 2015 9:28 am    Post subject: Reply with quote
Only pistons I can think of that would be almost 'off the shelf' would be Mahle VW flat tops at 87mm.
These need 22mm small end bushings or rods with 22mm small end.
Would have to check where that would leave you though with compression ratio. Can't remember off the top of my head.
Raceboy - didn't 'Racing' run 2bars with essentially a stock bottom end apart from pistons?
I think he kept stock cam though so probably didn't rev beyond 6500rpm.
1979 UK 932
Raceboy
PostPosted: Wed Sep 16, 2015 4:00 pm    Post subject: Reply with quote
Jesper (Racing) did rev the engine to 7000 and occasionally to 7200 but the K27 turbo he used did not pump as much air at 2bar as Pieters Garrett and he did not use E85 _> made less power too.
'83 924 2.6 16v Turbo, 470hp
'67 911 2.4S hotrod
'90 944 S2 Cabriolet
'78 924 Carrera GT replica
'84 928 S
'91 944 S2, sold
'82 924S/931 "Gulf", sold
'84 924, turbocharged, sold.
CÚdric
PostPosted: Wed Sep 16, 2015 4:31 pm    Post subject: Reply with quote
It could well be a combination of peak cylinder pressures and revs. Its easy to get extremely high pcp with E85 and high boost/aggressive timing since its not knocking. But i would have guessed the head gasket would have gone before it got to bad. But its hard to know if you cant measure it.
Stock rods are very heavy, the verdi rods that Joakim.s uses is approx almost half the weight of the stock ones. And that engine have had its fare share of beating around 7500rpm and high power figures. So it seems to work well.
BTW, great decision to continue with the 924 engine, this is one of my favorite threads! Have you logged any performance figures? 100-200 ?
PostPosted: Wed Sep 16, 2015 4:47 pm    Post subject: Reply with quote
Maybe it was just a coincidence? Could it be that that rod had a fabrication defect or has had a harsh life and now you've put it up to the test?
One incident does not confirm anything IMO.
Perhaps lightened and why not stregthened stock rods would hold to 2bar and 7200RPM. Is your valve train factory?
CÚdric
PostPosted: Wed Sep 16, 2015 5:01 pm    Post subject: Reply with quote
That is of course an important factor, could as well be just a coincidence, it could have held up for a year aswell, 1 engine is a small statistical sample
Getting lighter forged pistons+balancing of the bottom end will help aswell. Maybe shotpeen+polish the stock rods if you want to be on the safe side?
931 twinturbo
PostPosted: Tue Oct 18, 2016 2:55 am    Post subject: Reply with quote
Any updates?
911 Targa 1974 Turbolook/Outlaw
964 C2 1992mod
924 Carrera GTS Look(Project)
924Na stock 1982Mod
*911S Targa slantnose 1975mod
*924Na 1977Mod Carrera GT kit
*944NA Type 1 1984Mod
*924 Turbo Serie2 1980mod
*924 Turbo Serie2 1980Mod
*924NA 1982Mod
mikeycrum14
PostPosted: Fri Feb 03, 2017 9:08 am    Post subject: Total Newbie Reply with quote
Looking for performance upgrades on my NA 924. the engine is bone stock. five speed trans and a Stage 3 racing clutch (apparently). Looking to upgrade the engine cheaply and safely without ruining reliability. Ive heard about upgrading to EFI from the CIS. What would that entail? any suggestions on upgrades. minimal car knowledge (first car).
1981 924 - Alpine White
First car!
Fresh tune up, stage 3 racing clutch, stock otherwise, 5 speed trans. - SOLD
DutchPug
PostPosted: Sat Mar 04, 2017 9:43 pm    Post subject: Reply with quote
Update...; No time for this car. Have not even touched it since.
Have a spare engine and ordered billet connecting rods 4 months back, should be here soon. Still looking for pistons.
The idea is to make a stronger engine and upgrade both the intake and exhaust manifolds. But, don't hold your breath on updates
Page 7 of 7
