lower alternator bolt
Goto page Previous  1, 2
edredas
PostPosted: Wed Oct 05, 2016 1:05 am    Post subject: Reply with quote
Sorry about the cable. I would normally double check but I thought it was your original engine. I also could have swore that the cables were interchangeable. I should have checked, I have a car with the early cable and didn't notice until now that the early bracket has a larger hole.
I have a late bracket and that return spring if you can't get that cable to work.
'87 924S -Red, 300hp 951 swap
'87 924S -Red, New Project
'87 924S -White, Automatic
'88 924S -Red, Daily Driver, Bone stock
'93 Mx6 -White, Megan Racing suspension
jvandyke
PostPosted: Wed Oct 05, 2016 2:43 am    Post subject: Reply with quote
yeah, really you should know what engine is in a guy's car even when he doesn't!
Not a problem!
I don't know what is different between the two. We put it on but it seems too long. The one we took off (fire victim) is the same as the one you sent me so the DPO had it "wrong" too.
So am I right that we either need a cable (the kind as you've pictured, with the adjuster at the firewall and a different end at the throttle) to match the early plate, or I need a later plate?
I've asked around when shopping and they seem to be interchangeable, are the brackets the same "length" the arm that holds the cable? There's a lot of slack in the cable between the bracket end and the firewall, the cable has to bend and pinch.
Here's a shot of an '84 944, we have the eliptical cam on the throttle plate.
I'll put up a picture tonight.
87 924S project, '83 944 engine,
my son's first car.
edredas
PostPosted: Wed Oct 05, 2016 10:01 am    Post subject: Reply with quote
I measured the plates and it appears that the later plate is 10mm longer than the early plate. Not sure if that would make a difference but thought I would let you know. You might be able to slit open some washers to go on the cable and fill in that big hole... maybe that might work?
jvandyke
PostPosted: Wed Oct 05, 2016 11:40 am    Post subject: hole is okay, it's the length Reply with quote
This can't be right.
my son's first car.
edredas
PostPosted: Wed Oct 05, 2016 12:18 pm    Post subject: Reply with quote
Yeah, that isn't right... being like that might wear the cable out. I think the late bracket would fix it.
I also have a return spring and a six rib crank pulley if you're interested.
hdrider19
PostPosted: Wed Oct 05, 2016 1:53 pm    Post subject: Reply with quote
I am putting an 84 944 engine in my 87 right now. Throttle cable bracket seems to be the same on both engines.
87 924S
jvandyke
PostPosted: Wed Oct 05, 2016 2:20 pm    Post subject: Reply with quote
I must have done something wrong.
my son's first car.
edredas
PostPosted: Wed Oct 05, 2016 2:42 pm    Post subject: Reply with quote
You might have the same throttle brackets. I have them side by side and the early bracket is 10mm shorter and has a 15mm hole compared to 8mm for the late.
jvandyke
PostPosted: Wed Oct 05, 2016 2:44 pm    Post subject: Reply with quote
10mm isn't going to fix my problem, I don't think
I think I installed the engine 3 inches too far back.....
I must have a late bracket as it has the smaller hole.
Maybe i have issues on the pedal end, maybe that is adjusted poorly by PO to compensate somehow? Hmmm
my son's first car.
PostPosted: Thu Oct 06, 2016 2:21 pm    Post subject: Reply with quote
Not likely since the tranny would be 2 inches into the spare tire well....
jvandyke
PostPosted: Thu Oct 06, 2016 11:20 pm    Post subject: Reply with quote
kidding, of course although something is seriously weird
It works, we drove it but it ain't right.
my son's first car.
Page 2 of 2
