edredas
Posted: Wed Oct 05, 2016 12:05 am Post subject: |
Sorry about the cable. I would normally double check but I thought it was your original engine. I also could have swore that the cables were interchangeable. I should have checked, I have a car with the early cable and didn't notice until now that the early bracket has a larger hole.
I have a late bracket and that return spring if you can't get that cable to work.
_________________ '84 944 -White, Brown interior
'84 944 -Red, Automatic
'87 924S -Red, 300hp 951 swap
'87 924S -Red, Project Car
'88 924S -Red, Daily Driver |
jvandyke
Joined: 30 Mar 2016 Posts: 212 Location: Hudsonville, MI
Posted: Wed Oct 05, 2016 1:43 am Post subject: |
yeah, really you should know what engine is in a guy's car even when he doesn't!
Not a problem!
I don't know what is different between the two. We put it on but it seems too long. The one we took off (fire victim) is the same as the one you sent me so the DPO had it "wrong" too.
So am I right that we either need a cable (the kind as you've pictured, with the adjuster at the firewall and a different end at the throttle) to match the early plate, or I need a later plate?
I've asked around when shopping and they seem to be interchangeable, are the brackets the same "length" the arm that holds the cable? There's a lot of slack in the cable between the bracket end and the firewall, the cable has to bend and pinch.
Here's a shot of an '84 944, we have the eliptical cam on the throttle plate.
I'll put up a picture tonight. _________________ 87 924S project, '83 944 engine,
my son's first car. |
edredas
Posted: Wed Oct 05, 2016 9:01 am Post subject: |
I measured the plates and it appears that the later plate is 10mm longer than the early plate. Not sure if that would make a difference but thought I would let you know. You might be able to slit open some washers to go on the cable and fill in that big hole... maybe that might work? _________________ '84 944 -White, Brown interior
jvandyke
Posted: Wed Oct 05, 2016 10:40 am Post subject: hole is okay, it's the length |
This can't be right.
edredas
Posted: Wed Oct 05, 2016 11:18 am Post subject: |
Yeah, that isn't right... being like that might wear the cable out. I think the late bracket would fix it.
I also have a return spring and a six rib crank pulley if you're interested. _________________ '84 944 -White, Brown interior
hdrider19
Joined: 03 May 2016 Posts: 193 Location: Catawissa Missouri(40 mi sw of St Louis)
Posted: Wed Oct 05, 2016 12:53 pm Post subject: |
I am putting an 84 944 engine in my 87 right now. Throttle cable bracket seems to be the same on both engines. _________________ 87 924S |
jvandyke
Posted: Wed Oct 05, 2016 1:20 pm Post subject: |
I must have done something wrong. _________________ 87 924S project, '83 944 engine,
edredas
Posted: Wed Oct 05, 2016 1:42 pm Post subject: |
hdrider19 wrote: | I am putting an 84 944 engine in my 87 right now. Throttle cable bracket seems to be the same on both engines. |
You might have the same throttle brackets. I have them side by side and the early bracket is 10mm shorter and has a 15mm hole compared to 8mm for the late. _________________ '84 944 -White, Brown interior
jvandyke
Posted: Wed Oct 05, 2016 1:44 pm Post subject: |
10mm isn't going to fix my problem, I don't think
I think I installed the engine 3 inches too far back.....
I must have a late bracket as it has the smaller hole.
Maybe i have issues on the pedal end, maybe that is adjusted poorly by PO to compensate somehow? Hmmm _________________ 87 924S project, '83 944 engine,
Posted: Thu Oct 06, 2016 1:21 pm Post subject: |
jvandyke wrote: | I think I installed the engine 3 inches too far back.....
Not likely since the tranny would be 2 inches into the spare tire well.... _________________ White 87 924S "Ghost"
jvandyke
Posted: Thu Oct 06, 2016 10:20 pm Post subject: |
Paul wrote: | jvandyke wrote: | I think I installed the engine 3 inches too far back.....
Not likely since the tranny would be 2 inches into the spare tire well.... |
kidding, of course although something is seriously weird
It works, we drove it but it ain't right. _________________ 87 924S project, '83 944 engine,
