accessory belt issue
jvandyke
PostPosted: Thu Sep 15, 2016 3:49 am    Post subject: accessory belt issue Reply with quote
Trying to install power steering and alt/ac belt.
Here's what I have.
Managed to barely get AC belt on the pulleys but barely (still not toothed in correctly)
When I pull it up on Pelican I get several different sizes from 736mm to 1000mm, how is that possible? my 990 is on but not really
Power steering is way too short it seems. I have an 888 but see 950 mentioned, did Pelican send me the wrong one?
When I run it through a parts place as a 924s I get a 15370, as a 944 I get 15375 (37" and 37.5" respectively whereas the 888 I was given is the equivalent to a 34.9" belt, how did I get that?)
I will pick up a 37" belt on the way home.
I should probably get a longer one for the AC/alt too since I had to fight like mad to get "sorta" on.
Seriously, this should be the easy part........
87 924S project, '83 944 engine,
my son's first car.
PostPosted: Sun Sep 18, 2016 9:23 am    Post subject: Reply with quote
Running yet?
jvandyke
PostPosted: Sun Sep 18, 2016 12:24 pm    Post subject: Reply with quote
Paul wrote:
Running yet?
ha! no not hardly
Belts on, 370 was quite tight too but on
raditator and fans, hoses, done, have to tackle the vacuum hoses and harness install next, last big obstacle is figuring out all that vacuum routing.
my son's first car.
hdrider19
PostPosted: Sun Sep 18, 2016 12:52 pm    Post subject: Reply with quote
jvandyke wrote:
Paul wrote:
Running yet?
ha! no not hardly
Clark's garage has a pretty good vacuum diagram.
87 924S
