engine reinstall struggles
jvandyke
PostPosted: Tue Sep 06, 2016 2:11 pm    Post subject: engine reinstall struggles Reply with quote
Wow what a battle.
So after many struggles we have the engine hanging from an engine lift in the engine bay, the torque tube/drive shaft is engaged and bolted on, left side of the crossmember is bolted to the motor mount and the mount is bolted to the engine, the other side isn't even close to lining up, like a good inch off, any thoughts? Crossmember is not bolted to frame yet, all is hanging. Maybe we should bolt up the crossmember then struggle with the mounts??
87 924S project, '83 944 engine,
my son's first car.
hdrider19
PostPosted: Tue Sep 06, 2016 9:26 pm    Post subject: Reply with quote
I removed drivers side mount from my engine. Then loosely attached the crossmember and the steering shaft. I lowered the engine onto the passenger side mount. Then I put the drivers side mount onto the rubber mount and lined up and reinstalled the bolts from the mount to the engine.
87 924S
PostPosted: Wed Sep 07, 2016 11:43 am    Post subject: Reply with quote
I lower the engine out of the car with the cross member still attached to the engine.
When reinstalling, attach the cross member to the engine, then raise the front of the car high enough to slide it under the car. Then lift the engine/cross member and install.
jvandyke
PostPosted: Wed Sep 07, 2016 12:44 pm    Post subject: Reply with quote
okay will try that next time, getting it forward enough to get the driveshaft installed with the crossmember on seems tricky, no?
I've almost got it and should be okay now. It's always a major PITA the first time ain't it?
At one point I had to stop, drop the engine onto blocks pull the hoist and remove the front bumper, didn't have enough clearance to push the whole works back onto the drive shaft.
Learning!
my son's first car.
PostPosted: Wed Sep 07, 2016 12:55 pm    Post subject: Reply with quote
Attaching the cross member to the body is done after bolting up the torque tube.
I edited my previous post to make it more clear.
jvandyke
PostPosted: Thu Sep 08, 2016 4:53 am    Post subject: Reply with quote
Okay, that's essentially what I ended up doing, hoisting engine high enough and forward enough to engage drive shaft and bolt up the torque tube, then with mounts into crossmember, raise it up bolt to engine slowly while engaging steering shaft joint and bolting crossmember to frame. It's just fiddly. It's done so that's one more baby step ahead, now to start reattaching everything else.
my son's first car.
Post new topic   Reply to topic    924Board.org Forum Index -> 924S Discussions All times are GMT + 11 Hours
