We're in, first post '87 Introduction
Goto page Previous  1, 2, 3
PostPosted: Sun Jul 31, 2016 5:31 am    Post subject: Reply with quote
Take a long screwdriver, and hit the rod from the top. Er, tap it actually would be better~! There is an aluminum stop for the upper rod, but you can get around it.
hdrider19
PostPosted: Sun Jul 31, 2016 7:33 am    Post subject: Reply with quote
That's what I had to do on mine. I used a long thin punch and drove it out from the top down. Be careful not to damage the stop pin on top. Thin tapered punch will get you past it.
87 924S
jvandyke
PostPosted: Sun Jul 31, 2016 1:27 pm    Post subject: Reply with quote
Did that, no joy.
Took pressure plate bolts out via starter hole to pull the whole thing off, with bell housing on the bench I still can't budge it, drift, sledge hammer, PB Blaster, propane torch........
letting it sit overnight, again
BTW
what does the spring washer do? it had fallen apart, release bearing seems okay otherwise, not really enough left on the friction disc, dang clutch parts are expensive!!!
Maybe the spring washer rusted up and couldn't take being restored to life.
We have to decide now how much to replace.
87 924S project, '83 944 engine,
my son's first car.
hdrider19
PostPosted: Sun Jul 31, 2016 1:47 pm    Post subject: Reply with quote
I was looking at pics of the pin you can't get out. It looks like the lock bolt that holds it in is broken off in the hole at the bottom. The notched washer goes under the snap ring holding the throw out bearing to pressure plate fingers. Go to the how to page and find thread on 924S/944 clutch disc. I am doing that right now.
87 924S
hdrider19
PostPosted: Sun Jul 31, 2016 2:15 pm    Post subject: Reply with quote
I have an extra spring washer for throw out bearing. Pm me and I can send it to you.
87 924S
jvandyke
PostPosted: Mon Aug 01, 2016 4:29 am    Post subject: Reply with quote
super, I'll take it
The retaining bolt is out. That hole is clear, I can shoot PB Blaster into it and it comes streaming out the notch/flat in the shaft. I'm sure it's just seized and time, chemicals and muscle will get it......eventually.
my son's first car.
hdrider19
PostPosted: Mon Aug 01, 2016 5:43 am    Post subject: Reply with quote
Did you take a look at the how to on the clutch disk? I am modifying one right now for mine. I will put the spring washer in an envelope and mail it to you.
87 924S
jvandyke
PostPosted: Mon Aug 01, 2016 1:24 pm    Post subject: Reply with quote
I will go look at the how to.
Clutch fork shaft came out when a guy on rennlist suggested pounding it back in a little (not too far as to hit the stop on the other end) then start pounding back down, this eventually worked.
Needle bearings are toast.
off to look for this "how to"
my son's first car.
jvandyke
PostPosted: Fri Aug 05, 2016 1:26 am    Post subject: Reply with quote
Just for fun, here's the needle bearings, something is supposed to be along the edges of the races, I would think, to keep the needles and cages in there?
my son's first car.
edredas
PostPosted: Fri Aug 05, 2016 2:22 am    Post subject: Reply with quote
Yeah, there's supposed to be two plastic rings that center the bearings, but when they get old they break up and fall out.
'87 924S -Red, 300hp 951 swap
'87 924S -Red, New Project
'87 924S -White, Automatic
'88 924S -Red, Daily Driver, Bone stock
'93 Mx6 -White, Megan Racing suspension
Page 3 of 3
