ViktorTsoi
Posted: Mon Aug 01, 2016 12:25 pm Post subject: Lateral Runout in timing belt |
I replaced the timing belt on my car (engine is from an 87 924s) about 5k miles ago. I just put the balance shaft belt back on, and noticed that the timing belt moves in and out on the pulleys when it is running. About 1.5-2mm in and out, so not a lot but noticeable.
Is this normal, or is there an alignment issue with the pulleys?
I used a mix of parts from the original engine and the 924s engine due to the 944 crank pulley being bent and the power-steering bracket on the 924s engine was damaged. I don't see any run-out in any of the pulleys or waterpump. _________________ 1978 924 -parts car
1982 924 -sold
1985 944 |
