RobertN
Joined: 19 Apr 2015 Posts: 142 Location: Lisburn Co Antrim
Posted: Sun Jul 17, 2016 8:11 am Post subject: Cam belt cover refit |
Anyone know how to refit the cam belt cover. I wrestled with it to remove it to change cam belt and fix stat housing leak.
Driving me crazy!!  _________________ Robert.
Porsche 924 N/A 1984.
Electrical Engineering Sales to Control panel builders. |
Posted: Sun Jul 17, 2016 8:25 am Post subject: |
If it's driving you crazy, you're doing it right...you just need to suffer a bit longer. _________________ Toofah King Bad
brian19600
Posted: Sun Jul 17, 2016 9:57 am Post subject: |
When I bought mine, the cover was off. Is there a trick to getting it on? _________________ 78 924 |
Glemon
Posted: Sun Jul 17, 2016 1:21 pm Post subject: |
There may be a trick I am not aware of, but as I recall there was a bit of trial and error of pushing and pulling and trying to slip it on from different angles, some finesse and some brute force involved, but it should slide back into place without bending or gouging anything too bad.
Be patient and persistent, don't recall any sledge hammers or two foot pry bars needed to force it back. Good Luck! _________________ 88 924S
68 TR250
02 IS300 |
Posted: Sun Jul 17, 2016 4:41 pm Post subject: |
You can trim of some edges and it will be a much easier job  _________________ 1980 924 Turbo
Posted: Sun Jul 17, 2016 4:54 pm Post subject: |
| Rasta Monsta wrote: | | If it's driving you crazy, you're doing it right...you just need to suffer a bit longer. |
Thats about right
You can actually do a nasty cut to the timing belt if you're insistant.
Either trim it to fit or remove everything in front of it to install it. _________________ Supercharger and EFI kits
https://www.the924.com |
