RickF
Joined: 03 Aug 2015 Posts: 44 Location: Howell, NJ 07731
Posted: Tue Jul 05, 2016 6:18 am Post subject: Bleeder Valve & Shutoff Valve Testing? |
Is there a procedure for testing both the Bleeder Valve, (pt # 810201186A) and the Shutoff Valve, (pt # 92820108302) on an 87' 924S? I'm in the middle of a fuel tank conversion and have these valves exposed and would like to prove or replace them while they are exposed.
Thanks,
Rick _________________ Rick |
Posted: Tue Jul 05, 2016 7:11 am Post subject: |
If the ball is moving freely and the valve has no physical damage they are probably OK.
Having said that, there is a thread on Pelican discussing replacing at least one of the valves with a cheap unit. _________________ Toofah King Bad
RickF
Posted: Tue Jul 05, 2016 10:18 am Post subject: |
Thank you sir. I've been searching Pelican and can't seem to locate the thread you are referring to. _________________ Rick |
Posted: Tue Jul 05, 2016 3:24 pm Post subject: |
Linked in my plastic tank thread, I think. _________________ Toofah King Bad
