Noahs944
Joined: 08 Dec 2015 Posts: 782 Location: Calgary, Alberta, Canada
Posted: Tue May 31, 2016 12:07 am Post subject: |
morghen wrote: | The idea is NOT to lock up the wheels. | Yes but a good braking system should allow you to lock them up and then the next component to share the responsibility are the tires & the ground. Don't you agree? |
Posted: Tue May 31, 2016 1:34 am Post subject: |
I'm not an expert in brakes systems but I've never locked the brakes of any 924 unless on wet surface nomatter how hard i stomped the pedal. To be honest the most impressive brakes i've ever seen are the M030 big reds i have on my GTS wannabe, it outbrakes modern sport saloons from high speeds...on dry surfaces ofcourse...but those as well i have never locked unless it was on wet pavement. _________________ https://www.the924.com |
Noahs944
Posted: Tue May 31, 2016 3:08 pm Post subject: |
I am critical of ALL CARS coming from my late 944 because it is an engineering marvel and the brakes are sensational- easily twice the power of *my* 924s. I wish I could drive other 924s to compare.
I can handle the lack of engine performance, but the brakes aren't good enough. Bad brakes SUCK.
With the '44 I have locked up the brakes (very briefly) at higher than normal hiway speeds on a couple of occasions. A deer once and another time it was because of another driver not respecting my right-of-way. And yet a third time at slower speeds. In all three instances I was driving faster than I *should* be, but in all three situations the brakes saved the car & myself from physical damage. |
Posted: Tue May 31, 2016 4:10 pm Post subject: |
Hm, Gramps is an early one isnt he? Thats the actual problem...unless you didnt refresh the brake fluid and you're running water
How about upgrading the booster and master cylinder to later 924 ones..also used on 944s. That should make the brakes behave comparable to your 944. Ask Leigh to send you a 931 booster and master cyl, swap it in..refresh the brake fluid and get cracking. _________________ https://www.the924.com |
Kenodog
Joined: 25 Jun 2003 Posts: 2645 Location: Vancouver,B.C.
Posted: Tue May 31, 2016 11:03 pm Post subject: |
On my old '80 931 I did nothing more than refresh the entire system, rebuilt calipers, new pads, new master etc.,otherwise it was an M471 stock set up. A few time I hit the brakes at high speeds out of necessity and it damn near put me through the windshield. The factory 5-lugs from the M471 package are MORE than enough for any 924. They may be smaller than the big reds or 951 big blacks but since the car weighs 500 lbs lighter they work almost as well.
Me....Leigh _________________ 1979 Euro 931, Olive
1981 931, Sabine
1991 Ford Ranger XLT 4x4
1996 Ford E-350 ex-FedEx Van
2014 Mazda CX-5 (Kinderwagon)
2019 KTM 790 Adventure
2024 KLX300
2024 KLX140 |
