nightrunner68667
Joined: 22 Apr 2016 Posts: 11 Location: Jackson, TN 38305
Posted: Sat May 21, 2016 8:38 am Post subject: heater hoses |
Removed wur for cleaning so in the process of replacing all the heater hoses, and the many elbows, found a hose at Oreilly's (part # 18937), that works for the elbows, got 2 out of this hose plus the piece at the heater control valve ($12.22)
Ok, for the question, where does everyone get the hose that is real large on one end and small on the other? I have seen it for 40.00, is that for real? I will try and put a pic of the one that I am talking about.
Last question, what all has to come off to replace the elbow at the turbo??
O, one last question, where is the best place to get the hose that runs from the control valve to the heater core?
Thanks.
Darrell.
[img][/img][img][/img] _________________ Always wanting to learn. |
Posted: Sat May 21, 2016 9:25 am Post subject: |
If you check the tech section I think you'll find an article about removing that recirculation valve cover to address a rattle in the turbo. _________________ Toofah King Bad
nightrunner68667
Posted: Sat May 21, 2016 9:39 am Post subject: Heater hoses |
Found it, thanks. _________________ Always wanting to learn. |
