Minimum ride height for a 924?
Qik Nip
PostPosted: Sun Apr 10, 2016 11:35 am    Post subject: Minimum ride height for a 924? Reply with quote
My question has to do with readying the car (its a 1979 924) for Bonneville (where air resistance is everything). LSR aero guru's tell me that the closer the car is to the ground, the lower the effective frontal area and its air resistance.
Looking at the car's front suspension camber adjustment excentrics, it appears that the ability to offset the added camber that comes with lowering the front end is pretty limited.
My question then, is how low can I go and still get back to a fairly zero degree camber setting with that available adjustment?
'79 NA 924 Land Speed Car
Bonneville G/CPRO record holder @ 149.825MPH
'96 LT4 C4 daily driver
Great Lakes SCCA SM points champion '09,'10,'11
PostPosted: Sun Apr 10, 2016 3:08 pm    Post subject: Reply with quote
In theory, your control arms shouldn't go past horizontal.
Can you add some front aero? Like skirting?
PostPosted: Sun Apr 10, 2016 5:40 pm    Post subject: Reply with quote
I'm not an expert but your front area will still be the same lowered or not.
If you dont want air under the car you can lower it a bit and use a front lip.
You can lower it about an inch and still get 0 deg camber or very close if i'm not mistaken.
Can you get us some pictures of the car being prepared for this?
I'm guessing you're going without mirrors, the 924 small spoiler hatch, filled/closed panel gaps..right?
red 924 and not red 924
PostPosted: Sun Apr 10, 2016 10:53 pm    Post subject: Reply with quote
For what you're doing... who cares?
If the camber adjustment becomes a problem - camber plates are the answer.
Ours are past horizontal - and we turn!
'79 924 #77 ITB racecar
Qik Nip
PostPosted: Mon Apr 11, 2016 1:30 am    Post subject: Reply with quote
I thought the same thing, but the experienced land racers I talk to tell me that the effect of lowering a 72" wide car two inches (144 square inches) is effectively like reducing the frontal area by a square foot. Most LSR cars run absolutely as close to the ground as possible and that appears to be the reason.
If you don't want air under the car you can lower it a bit and use a front lip.
Unfortunately the class I'm running (Classic Production) forbids any non stock body additions / changes, so no air dam. I am runnning the stock lip.
I'll post one when I figure out the process.
Mirror removal is permitted but as mentioned above, no aero changes are authorized- to include taping up the body seams.
PostPosted: Mon Apr 11, 2016 4:10 am    Post subject: Reply with quote
IIRC you could order an NA with the 931 rear spoiler and that spoiler reduced CD.
Can you add one if it was an original option?
Qik Nip
PostPosted: Tue Apr 12, 2016 5:17 am    Post subject: Reply with quote
Eddie:
My understanding of the class rule is that if the 931 spoiler was factory option that could be ordered on the car from the factory, it is permissible. If it was a dealer add on, it's not. Was it a factory option available on the 79 NA car?
Rick
PostPosted: Tue Apr 12, 2016 6:14 am    Post subject: Reply with quote
It came on the 1979 924S along with 5 lug and vented rotors.
1979 924 NA race car
1982 924 Turbo almost a PoS
Qik Nip
PostPosted: Tue Apr 26, 2016 8:55 am    Post subject: Reply with quote
Eddie.
Thanks. That's what I suspected. Not legal on my NA car.
Rick
PostPosted: Tue Apr 26, 2016 8:57 am    Post subject: Reply with quote
Qik Nip wrote:
Eddie.
Rick
79 924S was an NA..
S was just an options package for the big breaks/5 lug and the spoiler on the NA
Qik Nip
PostPosted: Wed Apr 27, 2016 8:26 am    Post subject: Reply with quote
Fasteddie313 wrote:
Qik Nip wrote:
Eddie.
Rick
79 924S was an NA..
Hmmm. Now where to find said parts?
Post new topic   Reply to topic    924Board.org Forum Index -> 924 Racing Today All times are GMT + 11 Hours
