Posted: Fri Feb 12, 2016 5:32 am Post subject: Hesitating while revving 931 |
my 931 M31.01 was a perfect running car. I gave it a big service, new:
- spark plugs
- leads and distributor cap/ rotor
- oil/filter
- fuel filter
- cambelt
- valve adjustment
- boost controller
- fuel relay
After getting it all back to getter the car backfires and is hesitating while revving
O f course I tripple checked the cambelt timing and the ignition timing but that all seems te be good (checked with timing light).
What could it be ? _________________ 937 trackday car
Last edited by Dutch924-racer on Tue Feb 16, 2016 6:24 am; edited 2 times in total |
jazz guy
Posted: Fri Feb 12, 2016 5:48 am Post subject: |
If you're positive about cam and ignition timing, possibly a leak in the intake path. Charge pipe seal leak? Boost controller or line leak? _________________ '81/'81/'82 |
Posted: Fri Feb 12, 2016 10:41 am Post subject: |
Agree with Morghen, sounds like it's lean. _________________ Toofah King Bad
bear924
Joined: 26 Jul 2005 Posts: 95 Location: South West Queensland, Australia
Posted: Wed Mar 23, 2016 6:40 pm Post subject: |
I had an issue for a while where my car would hesitate and miss while revving under load, however not while revving without load. My problem was a faulty over boost switch. |
Posted: Wed Mar 23, 2016 6:54 pm Post subject: |
What boost you now running Joost? Anything over 1.0bar and you could be bumping into the overboost switch threshold which momentarily cuts fuel relay. You will get a major misfire from this which scares the life out of me when it happened a few times. I thought I had blown the engine or turbo. I disconnected/grounded the over boost switch
When the switch failed some years ago, it caused complete loss of fuel relay and therefore no power or acceleration at all.
A blocked fuel filter also made the car hesitant at the top end of the rev range, starving the engine of fuel.
As also mentioned, check every elbow and vac pipes. A leak may be opening up under full load and not seen when stationary.
Also had problem with a dizzy rotor wobbling at high revs and hitting the dizzy cap. Had to buy another brand of rotor to stop this happening. This caused a stutter at higher rpm _________________ 1980 931 - forged pistons, Piper cam, K27/26 3257 6.10 hybrid turbo, 951 FMIC, custom intake, Mittelmotor dizzy & cam pulley, H&S exhaust, GAZ Gold, Fuch'ed, Quaife
Posted: Wed Mar 23, 2016 11:39 pm Post subject: |
Carrera RSR wrote: | I disconnected/grounded the over boost switch |
As did I. _________________ Toofah King Bad
Posted: Thu Mar 24, 2016 1:06 am Post subject: |
Problem solved, it was the ignition switch/ control unit (under the left headlamp).
Looked like somthing burned inside it. Just replaced it with another one, and car run great again
Thank you all for the support! _________________ 937 trackday car
Posted: Thu Mar 24, 2016 1:22 am Post subject: |
I'd sure inspect the harness and make sure the unit didn't perish from "external" causes... _________________ Toofah King Bad
