Turbo rebuild
Pascal924
PostPosted: Tue Dec 29, 2015 6:20 pm    Post subject: Turbo rebuild Reply with quote
I have a turbo wich is leaking oil.
I want to replace the seals.
Do you have experience with the rebuild kits, from example ebay?
Do you need to balance the shaft if you remove the turbo wheels?
PostPosted: Wed Dec 30, 2015 4:09 am    Post subject: Reply with quote
People on the board have succeeded. I'm sure they'll chime in.
In the US, a professional rebuild (with computer balancing beyond the tech available when the turbo was new) is reasonably cheap. . .$350 when last I checked.
