alperx
Joined: 06 Nov 2014 Posts: 17 Location: Antalya, Turkey
Posted: Mon Sep 21, 2015 8:04 am Post subject: transmission upgrade |
hello
I saw that the shaft and the transmission on 924 is very thin and doesnt seem strong for a strong turbo setup.
which audi/VW stronger transmission fit in the 924 ?
Thanks |
motormouth
Posted: Mon Sep 21, 2015 4:04 pm Post subject: |
If i'm not mistaken Raceboy used the NA gearbox on his 2L turbo that made more power and torque than the standard 924 turbo. _________________ https://www.the924.com |
Raceboy
Posted: Mon Sep 21, 2015 4:21 pm Post subject: |
Dutchpug uses 924 NA torque tube and trans on his ~400whp 924 2.0, the engine threw a rod after upping the boost to 2bars but no signs of damage on the torque tube after several years of abuse. _________________ '83 924 2.6 16v Turbo, 470hp
'67 911 2.4S hotrod
'90 944 S2 Cabriolet
'78 924 Carrera GT replica
'84 928 S, sold
'91 944 S2, sold
'82 924S/931 "Gulf", sold
'84 924, turbocharged, sold.
Posted: Mon Sep 21, 2015 11:19 pm Post subject: |
I thought I had read that with the 924NA torque tube it is very difficult to upgrade the clutch. How was that done? _________________ Mike
'67 MG Midget Dp
Raceboy
Posted: Mon Sep 21, 2015 11:57 pm Post subject: |
I used Spec Stage 3+ clutch kit for 924 NA 215mm clutch, that was rated to ~400Nm iirc.
Pieter (DutchPug) had OEM pressure plate upgraded locally and used some other disc iirc. Check his thread, he wrote about it there. _________________ '83 924 2.6 16v Turbo, 470hp
'67 911 2.4S hotrod
'84 928 S, sold
'91 944 S2, sold
Posted: Tue Sep 22, 2015 2:12 am Post subject: |
A 944 transaxle is also a direct swap you have a more common input shaft size. |
Raceboy
Posted: Tue Sep 22, 2015 2:33 am Post subject: |
944 NA/924S trans is not stronger at all compared to 924 NA gearbox. Upgrade would be 944S/Turbo/S2 /968 6spd 01E gearbox. _________________ '83 924 2.6 16v Turbo, 470hp
'67 911 2.4S hotrod
'84 928 S, sold
'91 944 S2, sold
Posted: Tue Sep 22, 2015 3:53 am Post subject: |
I am interested because I want to be able to use the 4.11 dif gear of my '80 rather than switch to the 3.889 of the 944 as in my looking at the Haynes manual the change over to the 944 torque tube to gain clutch capacity looked quite daunting if wanting to retain the higher gear ratio. But then I have never taken a transmission apart. _________________ Mike
'67 MG Midget Dp
Posted: Tue Sep 29, 2015 7:33 am Post subject: |
MikeJinCO wrote: | I am interested because I want to be able to use the 4.11 dif gear of my '80 rather than switch to the 3.889 of the 944 as in my looking at the Haynes manual the change over to the 944 torque tube to gain clutch capacity looked quite daunting if wanting to retain the higher gear ratio. But then I have never taken a transmission apart. |
Torque Tube isn't that bad to remove and install as long as you drop the exhaust and the rear suspension. Really, I was able to do this in my garage by myself with a standard jack and jackstands to hold the car up.
That said, if you just want to update to a 5-speed Audi box from a later small spline 924, then it should bolt up to your 77 torque tube with only a change to the later 5-speed shift arm. Clutch splines and torque tube should all work as before (though it might not hurt to refresh the bearings, bushings and other wear items while you're in there).
The 944 swap just opens up the ability to use some of the more common later transaxles and aftermarket clutch discs. Unless you're going to V8 power levels or doing a lot of rally or road racing, I don't know that it is ultimately worth it in most cases. _________________ Stefan
Posted: Tue Sep 29, 2015 10:33 am Post subject: |
I have a transaxle from an 81 924. Shipping cost moght be more than it's worth though. |
alperx
Posted: Sun Nov 22, 2015 11:29 am Post subject: |
well
after all - I used a Hyundai diesel pressure plate with a 4-puck ceramic ACT clutch disc. we will see what happens. |
