Over the Top 968
PostPosted: Mon Oct 12, 2015 3:41 am    Post subject: Over the Top 968 Reply with quote
Oh, dear
http://www.worldtimeattack.com/index.php/dark-horse-cometh-rp-968-porsche/
  • Wei▀e Schei▀e (1987 924S) - In Progress
CÚdric
PostPosted: Mon Oct 12, 2015 6:17 am    Post subject: Reply with quote
There is a similar Swedish TA build,
https://m.facebook.com/profile.php?id=960036194040209
Extremely fast, and ambitious build. Omg, so muchmuch work!
┤79 924
┤80 924 Turbo
daniel
PostPosted: Mon Nov 02, 2015 3:38 pm    Post subject: Reply with quote
I called these guys once for a price to wheel align my 924. After receiving the price I needed to clarify if the price was infact to buy the wheel aligning machine...
1989 944 Cabriolet
gegge
PostPosted: Mon Nov 02, 2015 11:41 pm    Post subject: Reply with quote
767hp...
Carl Fredrik Torkildsen
Scott Sanda
PostPosted: Tue Nov 10, 2015 2:34 pm    Post subject: Reply with quote
Notice the intake and exhaust, they are swapped. I wonder how they timed it out. Does the head fit backwards, or did they need to re machine the ports....
I suppose nothing says you can,t have the intake cam on the right side of the motor, if you get everything correct.
Creates an interesting exhaust path, doesn't it?
PostPosted: Tue Nov 10, 2015 2:38 pm    Post subject: Reply with quote
They likely used a 928GTS head which is very similar and has one head that is mirrored.
PostPosted: Wed Nov 11, 2015 4:44 am    Post subject: Reply with quote
http://rennlist.com/forums/944-turbo-and-turbo-s-forum/899905-the-rp968-it-s-a-bit-of-a-thing.html
They actually put the head on backwards..
thingo wrote:
If you look closely you can see the new oil drains so we can switch the head around. We machined off the sprockets on the cams to give us more clearance.
Bleeders on what is now the high side of the head.
Intake
thingo wrote:
Thanks guys, rotating the head was not overly complicated, just the oil and water paths, it meant we could make a better exhaust manifold and we now have the hot and cold sides of the engine separated.
The intercooler radiator combo is from pwr, intake temps were 5 degrees above ambient
Custom engine and turbo mounts
1980 931S LSD FMIC hobby - 01 RS25 coupe - 95 M3 coupe - 06 X5
PostPosted: Wed Nov 11, 2015 4:47 am    Post subject: Reply with quote
Here is another thread on the same car.
http://rennlist.com/forums/924-931-944-951-968-forum/897281-the-rp-968-could-this-be-the-epitome-of-our-front-engined-watercoolers.html
I have been following it for a while..
Post new topic   Reply to topic    924Board.org Forum Index -> 924 Racing Today All times are GMT + 11 Hours
