924S2 Janne J
Janne J
PostPosted: Sun Nov 08, 2015 10:32 pm    Post subject: 924S2 Janne J Reply with quote
On a trackday i May 2015 the clutch broke ( the silly rubber center fell into pieces ), that was the start that i needed build the 924S i always wanted.
On a the Swedish website blocket.se i found this:
Day 1:
I changed the seals and ribs om the S2 Engine
I also modifyed the oil pickup with a support bracket
And then:
The external oil cooler from the S2 installed just under the bumper
After 12 Days the installation was finished and a friend and i was off to another trackday with the Swedish Porsche club:
A video from the last trackday of the season ( little to much windnoise..)
https://youtu.be/wA2wwgfw9FY
Porsche 924S 1988, Porsche 911SC 1982 Porsche 944S2 1990
KDJones2000
PostPosted: Mon Nov 09, 2015 5:44 am    Post subject: Reply with quote
Looking good!
Interesting how you don't have to have your windows down when out on the track. Here in the US it's required so people can pull you from the car in an emergency.
1987 924S SPEC car
Team Toofah Racing
1988 944 Turbo S
FelixP
PostPosted: Mon Nov 09, 2015 11:02 am    Post subject: Reply with quote
Looks great fun!
What size are those Fuchs?
1982 924 Turbo with Carrera GT kit, TMIC & DITC
PostPosted: Mon Nov 09, 2015 11:32 am    Post subject: Reply with quote
Very interesting conversion......tell us more! Original gearbox?
Love that track too!
PostPosted: Mon Nov 09, 2015 4:22 pm    Post subject: Re: 924S2 Janne J Reply with quote
Dear god, I'm lazy.
KDJones2000 wrote:
Interesting how you don't have to have your windows down when out on the track. Here in the US it's required. . .
Not at any club day I've been at. . .usual rule is windows all the way up or all the way down.
  • Wei�e (1987 924S) - 931 S3
Janne J
PostPosted: Mon Nov 09, 2015 5:20 pm    Post subject: Reply with quote
On these trackdays the windows should be closed, but cars without AC are allowed to have them slightly open to prevent the driver from getting overheated ( yes, it can be warm in Sweden sometimes )
My Fuchs is 7*15 ET23 and in the Pictures the tyres are Yokohama A032 205/50*15. A very light kombination that makes the car really alert.
The gearbox is original, 260000 kilometer / 161500 miles, it doesn't sound 100% healty anymore and is on the list of things to take care of..
PostPosted: Tue Nov 10, 2015 12:52 am    Post subject: Reply with quote
What wiring or ECU modifications were required?
PostPosted: Tue Nov 10, 2015 1:30 am    Post subject: Reply with quote
I'm sure the whole ecu had to come over with the twin cam harness and engine.
Janne J
PostPosted: Tue Nov 10, 2015 5:12 am    Post subject: Reply with quote
Yes, the S2 Engine was complete with wiring and ECU.
Here is the plan i did for the Electrics:
I used the connectors from the old 2,5 Engine to the S2 wiring.
New cables were needed to igniton coil and tachometer.
Janne J
PostPosted: Fri May 06, 2016 3:32 am    Post subject: Reply with quote
Now the brakes have been upgraded, Boxster calipers and discs from 911 carrera 3,2 in front and 944 turbo calipers and discs rear.
Swaybars also upgraded, 27 mm front and 19 mm M030 3 way adjustable rear.
A Fekzen chip added some power and more direct response.
Video from our first trackday 2016
https://youtu.be/vU-1yYWJBFQ
