Hope you can now see the picture!
theclassicera
PostPosted: Fri Jul 03, 2015 9:27 pm    Post subject: Hope you can now see the picture! Reply with quote
Didn't read the [img] bit in the how to psot, I am better with a machine tool than a computer!
[img]https://flic.kr/p/vwzE6H[/img]
theclassicera
PostPosted: Fri Jul 03, 2015 9:29 pm    Post subject: Maybe not then? Reply with quote
OAh well I will keep trying!
michaelodonnell123
PostPosted: Fri Jul 03, 2015 10:54 pm    Post subject: Reply with quote
The problem is your link. It should have a .jpg extension to work using the IMG button. Your current link is good but as a link to a webpage- not to show a picture.
MOD
1988 Porsche 924S
2007 Jaguar XK
2012 Fiat 500
PostPosted: Fri Jul 03, 2015 11:05 pm    Post subject: Reply with quote
There is a curbed arrow pointing to the right, you have to press that one and then you have to select BBCode and copy that link...then paste it here.
Trailer 1 by Haydn Earl, on Flickr
DSC03835 by Haydn Earl, on Flickr
red 924 and not red 924
theclassicera
PostPosted: Fri Jul 03, 2015 11:24 pm    Post subject: Thanks guys, think thats it? Reply with quote
Hope that you can now see the `works` seats in the car?
[img]new seat by Haydn Earl, on Flickr[/img]
theclassicera
PostPosted: Fri Jul 03, 2015 11:35 pm    Post subject: Theres no stopping me now! Reply with quote
Dual circuit bias adjustable pedal box.
[img]Pbox 2 by Haydn Earl, on Flickr[/img]
Spare wheel mount and rear harness bar.
spare wheel mount 1 by Haydn Earl, on Flickr
Front brakes
[img]Front strut in situ 1 by Haydn Earl, on Flickr[/img]
Machining the head to take 944 (Bosch injectors)
[img]Head 2 by Haydn Earl, on Flickr[/img]
PostPosted: Sat Jul 04, 2015 1:58 am    Post subject: Re: Theres no stopping me now! Reply with quote
Man I want one of those.. Very nice car and mods you have yourself there..
theclassicera
PostPosted: Mon Jul 06, 2015 6:29 am    Post subject: Pedal box Reply with quote
I can supply a copy of the box which is a direct replacement for the servo.
However if you still want servo assistance you would need either a dual circuit remote servo or dual servos.
I run with out any servo as I have 4 pot calipers front and rear and prefer the `feel'. They are quite powerful enough!!
PostPosted: Tue Jul 07, 2015 4:00 pm    Post subject: Reply with quote
I *love* the tire mount in the hatch!!!
PostPosted: Thu Jul 09, 2015 5:17 pm    Post subject: Reply with quote
nice one...
regarding your 3d printed stuff... and knowing f.all about it, would you mind expounding on this method... i.e wear resistance, heat range, make up of the materials/options...
cheers
theclassicera
PostPosted: Mon Jul 13, 2015 11:40 pm    Post subject: More about 3D printing Reply with quote
Hi Leadfoot, I am only printing the actual throttle bodies (more pics in separate post). The spindles, bearings and butterflies are all standard Webber DCOE parts so wear on these will be the same as a on a DCOE carb (minimal).
The printed bit is at the moment made from ABS plastic but I am experimenting with different materials and I have a University conducting independent tests, time will tell which is the best.
Heat should not be a problem, the material is Thermo set at very high temperature but again time will tell. This is very much at the prototype stage and I am concentrating on this type of body which is really only an air valve.
One of the great things about the 924 engine is that the injectors can be fitted into the head with good results rather than having them in the throttle body.
theclassicera
PostPosted: Mon Jul 13, 2015 11:45 pm    Post subject: Spare wheel in hatch Reply with quote
Another pic just for you Ideola
[img]Spare wheel by Haydn Earl, on Flickr[/img]
theclassicera
PostPosted: Fri Oct 16, 2015 7:49 pm    Post subject: Update........ Reply with quote
Just thought that you would like to know that this car is now up for sale due to an exciting new project.
Available as a rolling shell or might split if there is enough interest.
Also lots of engine parts.
Kenodog
PostPosted: Fri Oct 16, 2015 10:49 pm    Post subject: Reply with quote
Man, I would buy it in a heartbeat if it wasn't broken...):
Leigh
1979 Euro 931, Olive
1981 931, Sabine
2014 Mazda CX-5 (Kinderwagon)
2008 GS500
1996 Dodge Caravan (DJV)
vonmoogen
PostPosted: Sat Oct 24, 2015 1:08 am    Post subject: Reply with quote
You have PM
Rob
