My '78 924 NA
kuhdad17
PostPosted: Fri Aug 28, 2015 1:27 am    Post subject: Reply with quote
fiat22turbo wrote:
kuhdad17 wrote:
No worries on thread hijack.
Thanks for the input, I did move it to below the rail there as I believe that's the only way for sure to clear the rod. Of course, you have all kinds of room without the stocker airbox looks good though, thanks!
By the way, I love your hood "props". How did you go about doing that?
They are an early attempt. I need to move them inboard more to clear the strut tops. They are cheap "NASCAR" style aluminum hood props with hand made mounting brackets. Got tired of using a piece of shop vac tubing to hold the fibreglass hood up and figured I could do better.
[img]http://i.ebayimg.com/00/s/OTAwWDE2MDA=/z/XVMAAOSwPcVVgxhf/$_35.JPG[/img]
At least it was light weight....
'78 924 N/A
Johnny_Haywire
PostPosted: Fri Aug 28, 2015 9:06 am    Post subject: Reply with quote
All very good to know, gents, and thanks for doing the leg work. I'm hoping to pick up a few bits this weekend from a guy parting out a 924 and a 944. I'll definitely grab an expansion tank if there is one in good shape.
Thanks for the link, Stefan. Looking forward to checking it out.
1981 924 N/A 5-speed
Johnny_Haywire
PostPosted: Sat Aug 29, 2015 9:23 am    Post subject: Reply with quote
Did you get around to the injector seals yet, Kuhdad? I had my injectors out yesterday and the kit I got from Pelican Parts seems to be for the 2.5 EFI motor, not our 2.0 CIS. There are about 12 pieces in that kit, but we only need 4 larger o-rings.
Just wondering if you received a different kit.
kuhdad17
PostPosted: Sat Aug 29, 2015 1:20 pm    Post subject: Reply with quote
So the kit I bought originally was incorrect, I returned it and bought the seals from a local "Irish named" car parts store. I can get the part # if needed. They were less than two bucks a pop... Just make sure to pull the injectors straight up then I used a pick to pull the old seals. They were a tight fit for the new seals but I put them on first before putting the injectors back in.
'78 924 N/A
kuhdad17
PostPosted: Tue Sep 01, 2015 3:06 am    Post subject: progress... Reply with quote
Rest of my parts should be in today to finish everything else I'm doing. While I waited, I replaced my 10mm vacuum hoses. Still need to get to the next size up for the last of the hoses.
Here's my very pretty stability bracket for the airbox:
Back side:
The flattened side sits on the chassis and is bolted there.
The other side is bolted to the block in a space I'm assuming the powersteering pump pulley would be. Since I have a manual rack, I have a convenient hole.
Closer view:
I put rivets in the fender and where I wanted to place my ignition box.
Ignition box secured and lowered out of the way:
Final placement on tank:
'78 924 N/A
PostPosted: Tue Sep 01, 2015 3:40 am    Post subject: Reply with quote
I would unbolt the chassis side of that airbox brace and brace it back with a diagonal or two onto the engine. The engine vibrations will tear something apart there in short order if you leave it like that.
Ideally the airbox and brace should really only be supported by bracketry on the engine itself to avoid strain on the intake ducting.
The extra holes you used on the engine for the bracket are for the Emissions Airpump/A/C compressor. No 924 came with power steering from the factory. Only the 924S which only came with the 944's 2.5L.
kuhdad17
PostPosted: Tue Sep 01, 2015 4:16 am    Post subject: Reply with quote
Makes sense, I have yet to run it but I was planning on beefing up some of my support there, but I hadn't really thought about the vibration.
'78 924 N/A
kuhdad17
PostPosted: Tue Sep 01, 2015 6:38 am    Post subject: Reply with quote
Now I come to find out the fuel filter I ordered from Pelican Parts is not correct. Same thing as my injector o-rings. I don't think I'll be ordering from there again. Now to source a filter (the one on the motor only has German on it and is a Knecht FB 637).
'78 924 N/A
Johnny_Haywire
PostPosted: Tue Sep 01, 2015 10:33 am    Post subject: Reply with quote
Thanks for the updates on the expansion tank install. I picked one up this weekend along with a rear bumper for my 924. I'm gonna let you blaze the trail first, though ; )
Man, I'm going through the same BS with Pelican Parts right now, as well (and Rockauto, for other wrong parts). They want to charge $8.25 to ship the correct 4 o-rings? Screw that.
Autohaus AZ has the o-rings we need and their shipping is cheaper.
http://www.autohausaz.com/search/product.aspx?sid=tagq2fyaw2ych0eakq4t4255&makeid=800019@Porsche&modelid=1263271@924%20&year=1981&cid=22@Fuel%20%26%20Air%20System&gid=11223@Fuel%20Injector%20Seal
I was sent 2 incorrect fuel filters from Rockauto, so I ended up getting one from O'Reilly Auto parts for $9.97. Works fine, but does not have flow indicators, though it is the same design as the OEM one, so I just put it in the same way.
Autohaus also has what appears to be the proper filter:
http://www.autohausaz.com/search/product.aspx?sid=tagq2fyaw2ych0eakq4t4255&makeid=800019@Porsche&modelid=1263271@924%20&year=1981&cid=22@Fuel%20%26%20Air%20System&gid=6200@Fuel%20Filter
kuhdad17
PostPosted: Wed Sep 02, 2015 6:38 am    Post subject: Reply with quote
I've got a fuel filter on the way, we'll see how it does. It's a Wix 33016... My boss is pushing me to get the car out of the shop (he wants to work on the Saab he bought off his son). I may have to put the old one on so I can get it running and move it and then change later.
I got my o-rings from O'reilly's, they had to ship them. They are the green ones that Ideola had referred to in another part and seemed to work just fine. They were snug to get on but a little fuel helped ease them on. It's nice putting the injectors in and realizing they actually fit snug and tight as opposed to really really really easy to pull out.
As far as blazing the trail, once I start her up I should know what needs to be braced better as I have like 5 ideas in my head but don't want to go trying every one. I'll let you know!
My v-belt has been an adventure as well... I had a 15350, just tried a 15355, may need the 15360 now. Luckily these are easily found parts. New timing belt and tensioner now, cleaned up the outside of my water pump pulley, did some sand blasting and painting on some various pipes and supports and brackets. She's looking better...
'78 924 N/A
kuhdad17
PostPosted: Wed Sep 02, 2015 8:31 am    Post subject: Then I did this... Reply with quote
Snapped off a banjo bolt on the control pressure line, how does that even happen with the crush washers? I was tightening it up to torque specs and bam, that's it.
'78 924 N/A
kuhdad17
PostPosted: Wed Sep 02, 2015 8:52 am    Post subject: Reply with quote
backed it out and now on the hunt for a replacement. Maybe Parker Store.
'78 924 N/A
Wow, I have often worried about doing just that, but I've never seen it happen! At least you don't have to drill a hole...you should be able to *carefully* extract that using a LHD bit or extractor.
PostPosted: Wed Sep 02, 2015 10:13 am    Post subject: Reply with quote
Khal and Leigh I bet have a bucket of those little things.
Johnny_Haywire
PostPosted: Wed Sep 02, 2015 1:38 pm    Post subject: Reply with quote
She's really coming along - nice work on cleaning up that front end!
Bummer about the banjo bolt, but hopefully you can source one easily enough. If you have trouble, let me know, I'm going to visit that parts car again in a week and a half and will try to grab all the CIS bits I can. It's a 931 turbo, but I think the same fuel fittings up front.
I should have just used O'Reilly for the seals, they're my closest parts store. I gave P Parts hell about the screw-up with the seal kit and they gave me a refund, but I'm still out the time it took me to take it all apart. Ah, well.
Oh, one thing you might find interesting. The cashier told me that the O'Reilly house brand of filters (can't remember the name, Filtercraft or some such) is actually made by WIX. The one I picked up today actually has the flow indicator on it, though the one I currently have installed did not.
Page 3 of 4
