Shurick
Joined: 15 May 2005 Posts: 524 Location: Russia, Moscow.
Posted: Sun Aug 09, 2015 5:33 am Post subject: |
Fasteddie313 wrote: | That is sick!! great work
At 1.4 Bar/20psi you have to be getting around 300 crank hp you think? Maybe a bit more? |
According to fuel/air consumption from EFI datalog it must be 320-330 hp. Don't sure it's safe to run so much boost on a nearly stock engine. Also don't know how it will withstand longer drives. It may (and sure it will) demand higher capacity radiator for longer punishment than a one burst with wrong boost controller settings.
P.S. It's time to update my signature.=) _________________ WBR, Shurick
'86 924S -- R.I.P.
Shurick
Shurick
Posted: Wed Aug 26, 2015 7:41 am Post subject: |
Express G31 overhaul: http://www.youtube.com/watch?v=h5ihSjZad8U
Unfortunately, space on SD card ended up during gearbox disassembling. So it's not covered completely. _________________ WBR, Shurick
'86 924S -- R.I.P.
Posted: Wed Aug 26, 2015 9:43 am Post subject: |
Truly awesome.. _________________ 80 Turbo - Slightly Modified |
Posted: Wed Aug 26, 2015 4:30 pm Post subject: |
nice, what did you replace? _________________ https://www.the924.com |
Shurick
Posted: Thu Aug 27, 2015 7:28 am Post subject: |
morghen wrote: | nice, what did you replace? |
Retaining pins on the 2-3 gear fork jammed and fell off so I couldn't engage gears. _________________ WBR, Shurick
'86 924S -- R.I.P.
kcoyle
Joined: 15 Jan 2011 Posts: 712 Location: Long Island, NY
Posted: Thu Aug 27, 2015 8:15 am Post subject: |
Loved it! _________________ 1982 931- Stock with MBC at 8psi
Relax, all right? My old man is a television repairman, he's got this ultimate set of tools. I can fix it. |
Shurick
Posted: Wed Feb 15, 2017 10:45 pm Post subject: |
Almost forgot to tell a story about my new clutch disk.
Spec stage II disc died very fast for some unknown reasons. So I was looking for some alternative and found it for cheap.
Since I use M31/03 flywheel which shares clutch with 944, I can't use direct replacement like Mitsubishi Delica disc, but I manufactured a kit modify it:
'86 924S -- R.I.P.
Posted: Thu Feb 16, 2017 3:35 am Post subject: |
Shurick wrote: | 320-330 hp. Don't sure it's safe to run so much boost on a nearly stock engine. Also don't know how it will withstand longer drives. It may (and sure it will) demand higher capacity radiator for longer punishment than a one burst with wrong boost controller settings. |
Holding up well? Other than the clutch.. _________________ 80 Turbo - Slightly Modified |
Joined: 10 Dec 2006 Posts: 946 Location: Noosa Heads QLD Australia
Posted: Thu Feb 16, 2017 8:27 pm Post subject: |
Shurick.....so what exactly have you done with the clutch plate? _________________ 80/81 932/8 ROW |
Posted: Thu Feb 16, 2017 9:45 pm Post subject: |
Right, share with us the materials used to make yourself a cheap clutch please. _________________ https://www.the924.com |
Shurick
Posted: Fri Feb 17, 2017 9:26 pm Post subject: |
Fasteddie313 wrote: | Shurick wrote: | 320-330 hp. Don't sure it's safe to run so much boost on a nearly stock engine. Also don't know how it will withstand longer drives. It may (and sure it will) demand higher capacity radiator for longer punishment than a one burst with wrong boost controller settings. |
Holding up well? Other than the clutch.. |
It runs well on 1.1 bar of boost with no issues at all, but I feel it needs larger radiator. Will try to install two-pass aluminium radiator, bigger injectors and bigger oil cooler. And crank up boost to 1.3-1.4 bar. _________________ WBR, Shurick
'86 924S -- R.I.P.
Shurick
Posted: Fri Feb 17, 2017 9:29 pm Post subject: |
peterld wrote: | Shurick.....so what exactly have you done with the clutch plate? |
I made a spacer and heat-treated bolts, drilled out the rivets in clutch and installed spacer.
Much like in this thread, but my spacer is reusable and more solid to accept higher torque. _________________ WBR, Shurick
'86 924S -- R.I.P.
Posted: Fri Feb 17, 2017 10:37 pm Post subject: |
Yes, I see that...and a very nice job too.
What was the clutch plate from, that you modified? There are no Bronco 11s in Australia, so I'm wondering whether it was a common Euro car. _________________ 80/81 932/8 ROW |
Shurick
Posted: Sun Feb 19, 2017 12:30 pm Post subject: |
peterld wrote: | Yes, I see that...and a very nice job too.
What was the clutch plate from, that you modified? There are no Bronco 11s in Australia, so I'm wondering whether it was a common Euro car. |
It was Mitsubishi Delica diesel clutch plate. I'll post a p/n tomorrow, I need to get back to my home pc to find it. By the way, I can supply the pacer and bolts if you need. _________________ WBR, Shurick
'86 924S -- R.I.P.
