Camber adjustable top mounts
theclassicera
PostPosted: Tue Jul 14, 2015 12:48 am    Post subject: Camber adjustable top mounts Reply with quote
Thought you might like to see these that I have machined for my rally car.
[img]Latest top mount 2 by Haydn Earl, on Flickr[/img]
MikeDanger
PostPosted: Tue Jul 14, 2015 7:13 am    Post subject: Reply with quote
those have a likely hood of bending, no support in the middle
theclassicera
PostPosted: Tue Jul 14, 2015 7:57 am    Post subject: Reply with quote
They are supported by the strut brace tower.
PostPosted: Tue Jul 14, 2015 10:04 am    Post subject: Reply with quote
They'll raise the front of the car by about 2" and if you adjust the sprig height to compensate you can run out of strut travel in a hurry.
This is why the undermount camber plates only really work with shorter struts.
Should work well for a Rally car though.
theclassicera
PostPosted: Tue Jul 14, 2015 7:15 pm    Post subject: Reply with quote
Yes that is a problem, I have used standard strut cases with the spring pans cut off and then welded an adjustable platform as low as it will go.
As you say its fine for a rally car where I need some ground clearance.
A shortened strut will be the way to go for tarmac or modify the inner wing to move the upper mount upwards.
PostPosted: Wed Jul 15, 2015 12:27 am    Post subject: Reply with quote
These are a better design:
To give you an idea since you have access to machine tools, it shouldn't be impossible to build something similar with larger base material.
Good luck! Let us know how you get on with the Rally efforts.
