Air intake duct hitting hood when closed
Muz924
PostPosted: Sun Apr 26, 2015 9:13 pm    Post subject: Air intake duct hitting hood when closed Reply with quote
Hey Guys,
As the title says, my intake duct is hitting the hood (bonnet as we call it in Aus) when closed. It also clashes with headlight mechanisms.
The filter box is all lined up with the factory brackets & the hood/bonnet is aligned with front panels, however there doesn't seem to be enough room!
The filter box/air intake assembly is from my parts car being a 1980 model and the car is a 1978.
I have noticed the earlier 924's had a slightly different air intake duct where the intake runs down towards the back of the head light & latter run across towards the centre of the car.
Are the latter intakes not compatible with early models cars?
I would have thought they are all the same.
Later on left -------------------------------------------------- Early on right
1978 924 RoW 5-Speed (Current Project)
1980 924 RoW 5-Speed (Donor Car)
1985 Alfa Romeo Alfetta GTV 2.0 (Previous Project Car)
Muz924
PostPosted: Wed Jul 01, 2015 10:53 am    Post subject: Reply with quote
I ended up buying an "early model" intake & after a little fiddling all is good under the hood
PostPosted: Wed Jul 01, 2015 5:02 pm    Post subject: Reply with quote
surely you mounted it wrong...they should not be different.
Muz924
PostPosted: Thu Jul 02, 2015 8:33 am    Post subject: Reply with quote
The early intake is a lot smaller than the later, if i put the the later intake on it still hits
I wonder why they changed them for the latter models ? Better air flow maybe?
Cheers
