Posted: Wed May 27, 2015 3:06 am Post subject: knurling pieces to restore tolerances.. |
I have seen some stuff about knurling piston skirts to increase their OD in order to bring the piston-bore clearance tolerances back into check...
Like this...
from http://www.pbase.com/stealthfti/image/53355694
But anyway I was curious if this method would work on other clearance sensitive parts that experience wear on there OD surfaces..
Say maybe g31 synchro rings? _________________ 80 Turbo - Slightly Modified |
Posted: Wed May 27, 2015 3:24 am Post subject: |
I don't believe the issue with synchro rings to be one of clearances, but rather of finish.
Interesting thought, though. _________________ erstwhile owner of just about every 924 variant ever made |
Posted: Wed May 27, 2015 4:05 am Post subject: |
"Our new Carbon Moly Synchros have a new and improved proprietary composition that promotes Quick & Smooth shifting in addition to a more dependable braking surface. With a stronger brass body and improved locking angle, our Carbon Moly Synchros will take your tachometer to the limit."
http://gearspeedpartsstore.com/products.html
I wonder if this coating could be applied to our existing worn rings to add a few thou of OD and give a nice friction surface
Maybe I'll call them... _________________ 80 Turbo - Slightly Modified |
Posted: Wed May 27, 2015 4:14 am Post subject: |
Called them, they said it sounded possible but the way they manufacture them it may not be plausible to run a one off set...
And to call back tomorrow after he finds out more for me..
Seems brass syncros with this coating are very popular with honda car people revving to 11k rpm and such.. _________________ 80 Turbo - Slightly Modified |
jason c
Posted: Thu May 28, 2015 12:05 pm Post subject: |
| ideola wrote: | I don't believe the issue with synchro rings to be one of clearances, but rather of finish.
Interesting thought, though. |
Its not just the frictional surface inside the synchro ring but also the cone that the synchro rides on. When the cone wears down, the synchro will bottom out before the synchro has reached its full life. Syncro useful life is directly related to cone wear. |
Posted: Thu May 28, 2015 12:25 pm Post subject: |
Knurl em both, that should "synchronize" their speeds quite well..
Ha ha, no..
I did find G31 2nd syncros from $42 used 928 ones to $70 new 931 ones tho..
No new 928 ones.. _________________ 80 Turbo - Slightly Modified |
