canyonblaster
Joined: 20 Aug 2012 Posts: 391 Location: Denver, CO, USA
Posted: Thu Apr 23, 2015 3:24 am Post subject: WTB - windshield moldings and clips |
According to Safelite:
Apparently somewhere along my cars life some dipstick glued the windshield instead of using the proper clips. I especially need the passenger side strip and clips but sourcing all three pieces and all the clips pwould be ideal.
Anyone have any ideas for me?
Thanks! _________________ PCA Licensed Club Racer & Driving Instructor Current P cars: 1981 931
Past P cars, 1985 944, 1987 951, 1990 911 C4, 2002 Boxster S, 2005 996 GT3, 2013 911 C2S
Daily Driver P cars: 2008 Cayenne GTS, 2013 Cayenne GTS |
Posted: Thu Apr 23, 2015 3:31 am Post subject: |
Put a later flush 944 windshield in and ditch the clips, etc.? _________________ Stefan
Posted: Thu Apr 23, 2015 5:55 am Post subject: Re: WTB - windshield moldings and clips |
canyonblaster wrote: | According to Safelite:
Thanks! |
??? Windshield is supposed to be glued to the body?
The side trims are held in with about 16 clips. They can still be bought from Porsche. The side trims I'm not sure if still available. The rubber infill to the side trims is NLA. _________________ 1980 931 - forged pistons, Piper cam, K27/26 3257 6.10 hybrid turbo, 951 FMIC, custom intake, Mittelmotor dizzy & cam pulley, H&S exhaust, GAZ Gold, Fuch'ed, Quaife
canyonblaster
Posted: Thu Apr 23, 2015 6:40 am Post subject: |
fiat22turbo wrote: | Put a later flush 944 windshield in and ditch the clips, etc.? |
great idea. anyone know if this is possible? _________________ PCA Licensed Club Racer & Driving Instructor Current P cars: 1981 931
Posted: Thu Apr 23, 2015 6:45 am Post subject: |
The clips only hold the trim in place, the windshield is still glued-in. _________________ '83 944 Track car.
2001 Ford F350 powerstroke |
canyonblaster
Posted: Thu Apr 23, 2015 6:55 am Post subject: |
Grenadiers wrote: | The clips only hold the trim in place, the windshield is still glued-in. |
someone glued the trims.... _________________ PCA Licensed Club Racer & Driving Instructor Current P cars: 1981 931
Posted: Thu Apr 23, 2015 7:27 am Post subject: |
canyonblaster wrote: | fiat22turbo wrote: | Put a later flush 944 windshield in and ditch the clips, etc.? |
great idea. anyone know if this is possible? |
From what I remember of reading the posts about this, the replacement windshields for the early 944's without the antennae have a spacer built in and all that is needed to install is to remove the clip mounts, glue the window in and replace or modify the wiper arms to clear the window. _________________ Stefan
canyonblaster
Posted: Thu Apr 23, 2015 8:00 am Post subject: |
found a used right side from DC Auto, $70. the clips are still available from dealer, steep! $12/each. _________________ PCA Licensed Club Racer & Driving Instructor Current P cars: 1981 931
jason c
Posted: Thu Apr 23, 2015 11:32 am Post subject: |
There are a few different types of 944 windshields. There are also a few different installation methods & seals. The early 944 windshield is smaller than the flush mount so when brought up to flush mount height, it will be short on the sides. The windshield with the encasement is for flush mounting as it has the groove built in to hold the rubber trim surround. There use to be a larger windshield made (not sure if they still make it) for a flush mount that didn't have the encasement. You have to glue the rubber trim down or find a rubber trim that wraps around the side of the glass. You can find this trim at a glass shop in generic bulk, just cut to length. I used this method on my 951 racecar because I used a lexan window.
MikeDanger
Posted: Thu Apr 23, 2015 3:33 pm Post subject: |
you can come take mine for $50! _________________ It was either this or a giant box of legos |
brian19600
v8carreragts
Posted: Tue Apr 28, 2015 3:25 am Post subject: |
The late windshield is an easy job. You need the 87 and newer glass. This glass has a thick rubber spacer attached to the glass that spaces it up. It just gets glued into the same place after you remove the little stubs that hold the trim clips. The rubber part has the attachment groove for the rubber trim. It just gets pushed in after the glue sets up. I have this glass in my car.
The 85.5-86 glass used a metal spacer that slipped onto the pinchweld but it is NLA. _________________ 84 944--924 Carrera GTS clone w/520HP Chevy 302 V8--RUNNING!
2015 AUDI Q7
2013 Dodge Charger R/T AWD HEMI
2013 Chevy Cruze |
canyonblaster
Posted: Fri May 01, 2015 10:09 am Post subject: |
V8 - thanks. PM sent _________________ PCA Licensed Club Racer & Driving Instructor Current P cars: 1981 931
