How to Install a Rear Sway Bar on a 924 without one
Goto page Previous  1, 2, 3, 4, 5  Next
PostPosted: Tue Jun 29, 2010 2:00 pm    Post subject: Reply with quote
Yes it is possible, and factory parts are still available, cheep:
477 501 095 - Mounts (2)
133 411 333 - Retaining bows (2)
isuras2
PostPosted: Tue Jun 29, 2010 9:18 pm    Post subject: Reply with quote
I know the parts are available. I was more interested in if there would be interference that would make welding difficult.
Rob
'80 931 (sold)
'80 924 NA (sold)
Former Omaha Crew
gerben1986
PostPosted: Mon Jan 10, 2011 12:43 am    Post subject: Reply with quote
I'm also thinking about this conversion, but how many work is it to remove and reinstall the eccentric bolt on the arms?
Because I believe that bolt is for adjusting the wheel. Do you need to readjust it after installing the sway bar?
gerben1986
PostPosted: Fri Mar 04, 2011 7:35 am    Post subject: Reply with quote
I've done this job last saturday.
We had a carbridge, and then it can be done very quickly.
But we spend a lot of time measuring, lunching, and so on.
The most difficult part was to remove the old centric bolt and to get the U-turns around the torsion tube.
PostPosted: Fri Mar 04, 2011 8:27 am    Post subject: Reply with quote
No.
PostPosted: Wed Mar 21, 2012 3:33 pm    Post subject: Reply with quote
pocketscience wrote:
leadfoot wrote:
Whiteline sell brackets to mount the rear swaybar - KU3 universal fits the best
CORRECTION: Does not f*cking fit.
Grrrr, sh1t, bugger, f*ck.
saw this...
??? think all it took was to groove the torsion carrier a couple of mils top + bottom with a round file and I got the loops to snug up to the carrier tube....
the whiteline kits has very chunky straight bars that run across the torsion bar too, think I may have flat filed the torsion bar in that area also again to make sure it stayed put, this was all in situ stuff as I didn't pull the carrier off...
maybe the 95 diameter would have suited better then??
Gav what issues did you have???
chris79
PostPosted: Tue Mar 17, 2015 7:04 pm    Post subject: Reply with quote
I vould like buy sway bar of turbo 924 and install on my '79 924 na, that has not sway bar front and rear.
It's possibile without any problem ?
PostPosted: Tue Mar 17, 2015 7:32 pm    Post subject: Reply with quote
If your car is from Europe, you have a both front and rear sway bars.
If your car is from USA it may be possible that you dont have the rear one, but the front sway bar is 100% surely there.
chris79
PostPosted: Tue Mar 17, 2015 8:05 pm    Post subject: Reply with quote
Are you sure ?
I have not seen, then I have to look better under the car.
PostPosted: Tue Mar 17, 2015 8:14 pm    Post subject: Reply with quote
Unless someone took them out, you should have them.
chris79 wrote:
Are you sure ?
chris79
PostPosted: Tue Mar 17, 2015 8:19 pm    Post subject: Reply with quote
but sway bar of turbo are more rigid, this can make some improvements ?
Or I have to change even shock absorbers ?
kcoyle
PostPosted: Tue Mar 17, 2015 11:20 pm    Post subject: Reply with quote
You need to look under your car, take lots of photos, and post them.
And get a copy of the PET as well to so you can identify the parts.
http://www.porsche.com/usa/accessoriesandservices/porscheservice/originalparts/originalpartscatalogue/
Suspension reading here, detailed and informative.
http://www.clarks-garage.com/shop-manual/susp-15.htm
And get a haynes manual of some sort.
1982 931- Stock with MBC at 8psi
Relax, all right? My old man is a television repairman, he's got this ultimate set of tools. I can fix it.
chris79
PostPosted: Wed Mar 18, 2015 1:06 am    Post subject: Reply with quote
Have you some photos of sway bar installed at front and rear ?
PostPosted: Wed Mar 18, 2015 1:51 am    Post subject: Reply with quote
chris79
PostPosted: Wed Mar 18, 2015 7:11 am    Post subject: Reply with quote
ahahahahah
I have no sway bar front and rear:
FRONT
REAR
there are not other bars.
Page 4 of 5
