chris79
Posted: Tue Mar 03, 2015 4:46 am Post subject: |
But before install a turbo kit i have to rebuild Engine to prevent damages due to increasment of power? There is some kits For sale in web? |
Raceboy
Posted: Tue Mar 03, 2015 5:15 am Post subject: |
We both installed turbo on the engine without opening it up and no rebuild.
What kit do you mean? If turbo kit, there is no kit for 924 available. In past, there was a BAE kit but it is very difficult to find, turbo is usually blown and you get maximum of ~160 hp out of it.
Your only way to get a turbo on your 924 is either a) build it yourself, b) have someone make it.
The last option will be expensive because labour usually costs 2/3 of the total cost while 1/3 is parts. _________________ '83 924 2.6 16v Turbo, 470hp
'67 911 2.4S hotrod
'90 944 S2 Cabriolet
'78 924 Carrera GT replica
'84 928 S, sold
'91 944 S2, sold
'82 924S/931 "Gulf", sold
'84 924, turbocharged, sold.
chris79
Posted: Tue Mar 03, 2015 6:38 am Post subject: |
but turbo 924 has different pistons, head, compression, ecc, the reliability of engine is not compromised ? |
Posted: Tue Mar 03, 2015 7:33 am Post subject: |
If your name is Raceboy or DutchPug then no _________________ https://www.the924.com |
Raceboy
Posted: Tue Mar 03, 2015 4:07 pm Post subject: |
Lol stock 931 pistons are worse than 924 ones.
Haha morghen, good one! _________________ '83 924 2.6 16v Turbo, 470hp
'67 911 2.4S hotrod
'84 928 S, sold
'91 944 S2, sold
Posted: Tue Mar 03, 2015 5:02 pm Post subject: |
Wow. You give 'em books and they just eat the covers.
SOME CAN TURBO OR SUPERCHARGE A STOCK 924 ENGINE.
If you know what you're doing or are willing to learn and fail as you go.
IT WILL BE COMPLETELY CUSTOM AS THERE IS NO "KIT" AVAILABLE ANYMORE.
Chris, you need to do some reading on how turbochargers work and their concepts before you even think about trying to add one to your car. _________________ Stefan
WEASEL149
Posted: Tue Mar 03, 2015 9:54 pm Post subject: |
Knowing what you're doing with engine management and tuning is key in my opinion.
Good control over fuelling and ignition timing and being able to monitor what's happening is critical, if components are to survive.
Raceboy and DutchPug both know what they're doing with VEMS.
If you look at the other cars Raceboy has installed VEMS to you'll see he's an expert at it (which is why I've asked for his help with my own project).
I agree with fiat22turbo though - read/research as much as possible before you attempt anything, as you need a good understanding first.
Regardless though, what Raceboy and DutchPug have achieved with a turbocharged 924NA is very impressive _________________ 1979 UK 932 |
chris79
Posted: Tue Mar 03, 2015 10:20 pm Post subject: |
ok, i found solution for my tuning, I buy a ticket for Italy fro Raceboy and DutchPug |
Posted: Tue Mar 03, 2015 11:09 pm Post subject: |
He must want to beat Joachim then _________________ https://www.the924.com |
WEASEL149
Posted: Tue Mar 03, 2015 11:23 pm Post subject: |
morghen wrote: | He must want to beat Joachim then |
HA! Good luck with that one! _________________ 1979 UK 932 |
DutchPug
Joined: 27 Jul 2008 Posts: 94 Location: the Netherlands
Posted: Wed Mar 04, 2015 7:25 am Post subject: |
haha nice to read the comments. Think the best for Chris is to read up (a lot) before starting a project that could take years to get finished successfully if you don't have the right knowledge or support (and it will cost a bit too).
As said before will keep the 924 engine for a bit. So have started on the next improvement; the intake manifold.
The idea is to print the intake completely in ABS for testing (besides that simply like to see if i can print an entire intake) and then have one milled... since i don't think the ABS will hold up too long. Objectives are; much better top end performance than the stock intake and I don't want to change the throttle body position.
Here the design;
Already printed a couple of runners to do some measurements;
chris79
Posted: Wed Mar 04, 2015 8:06 am Post subject: |
And then you can create a kit for my happiness |
Raceboy
Posted: Wed Mar 04, 2015 3:09 pm Post subject: |
Chris, your priorities are a bit off. Having a kit does not mean you can slap parts on and start driving it at full tilt.
Having someone make the piping for turbo isn't also a big problem, but you need to convert the engine to EFI and then tune it also. And when tuning one mistake with igntiion table can be the end of your engine. No joke. _________________ '83 924 2.6 16v Turbo, 470hp
'67 911 2.4S hotrod
'84 928 S, sold
'91 944 S2, sold
chris79
Posted: Wed Mar 04, 2015 8:49 pm Post subject: |
I was kidding, I still have a lot to learn before tuning Engine. |
chris79
Posted: Fri Mar 06, 2015 1:01 am Post subject: |
If I change only flow of Air and fuel with valves and butterfly increased, leaving mechanic original, I have to masde other changes to cilinder compression and k jetronic injection ? And costs ?
(assuming I open head myself) |
