DZGunner
Joined: 18 Nov 2014 Posts: 172 Location: Great white north
Posted: Fri Jan 16, 2015 7:43 pm Post subject: |
I need a turbine wheel. I'll call either place. Or no no I really should go that way. It's the only option. _________________ 1979 porsche 924 Na
Have u ever driven a turbo. |
Posted: Thu Feb 26, 2015 5:26 pm Post subject: |
it goes to the intake manifold, its the boost/vac signal to the recirculating blow off valve or bypass valve..
it being cracked is an intake vacuum leak and will make the engine run bad..
oil from there is probably coming from the compressor side of your turbo.. _________________ 80 Turbo - Slightly Modified |
