TYPE111
Joined: 09 Feb 2014 Posts: 76 Location: Perth, Western Australia
Posted: Wed Jan 28, 2015 10:15 pm Post subject: Fuel Leak At Base Of Tank - What Gasket |
The big nut which goes into the bottom of the tank is dripping, tried to tighten it up but still drips. Looked as though the PO has but gasket sealant around it in the past. Tried to do if again but too wet with fuel.
Is it a rubber or cork gasket or should the gasket sealer be used again?
Cheers
David _________________ Trust, Then Verify |
Posted: Thu Jan 29, 2015 12:33 am Post subject: |
New ones are rubber, Pelican has them for $8.25 part number, 928-201-187-02-M100 _________________ '83 944 Track car.
2001 Ford F350 powerstroke |
Creech
Joined: 11 Mar 2014 Posts: 18 Location: Frankfort, KY USA
Posted: Thu Jan 29, 2015 11:57 am Post subject: |
Ordered mine from Pelican. Little tip, find another way to drain the fuel tank before just cracking it open from there. I drove with the gas light on for a day and figured it would be low enough. Nope. Spilled a couple gallons of gas in the driveway.  _________________ 1981 Porsche 924 NA |
TYPE111
Posted: Thu Jan 29, 2015 10:20 pm Post subject: |
Had a comment that the nut doesn't look standard. Can't see how to post a pic. Can anyone take a pic of the connection at the bottom of their tank to see if it's the same as mine.
Cheers _________________ Trust, Then Verify |
Posted: Fri Jan 30, 2015 12:06 am Post subject: |
Pelican or Autohausaz, has the entire 'nipple', fuel filter, o-ring as a complete unit.
Ok, found my spare, it's from Autohausaz.com, comes with an o-ring, don't order one separately. Taking the pic with my 951~!
