Stu2j
Joined: 03 Nov 2002 Posts: 1285 Location: Virginia Beach, VA
Posted: Wed Nov 27, 2002 9:44 am Post subject: |
hehehe, well judging from the 944 haynes manual I have,
you might as well do the timing belt and water pump at the same time,
in this piece is your cam shaft so you have to pull this and put the cam in the new one,
(if you are not REALLY mechanicly enclined I wouldn't recomend attempting this)
I would suggest getting the part if you are in need of a timing belt change, and just instruct the mechanic who is doing it to use this part instead _________________ 3 928s, |
Stu2j
Posted: Wed Nov 27, 2002 9:51 am Post subject: |
""I would suggest getting the part if you are in need of a timing belt change, and just instruct the mechanic who is doing it to use this part instead""
Crud, I figured as much.
If I were in need of front end service, I would probably pick this up. Those powder coated parts certainly look nice. Oh well... _________________ -Stu
924 owner since 1988
924S owner since 2002
Click here to view them: |
Posted: Wed Nov 27, 2002 9:59 am Post subject: |
well u can always get it and then put it on at next engine service _________________ 3 928s, |
exc911ence
Posted: Wed Nov 27, 2002 1:49 pm Post subject: |
THAT is one hot looking cam cover! Best I've seen since that Miata valve cover with the airbrushed flames I saw on eBay a year or so ago. _________________ 1975 911S |
Posted: Thu Nov 28, 2002 1:12 am Post subject: |
it is very easy to do if you have access to a powder coating place _________________ 3 928s, |
speedsta2003
Joined: 12 Nov 2002 Posts: 302 Location: Lincoln, Nebraska
Posted: Mon Dec 02, 2002 10:41 am Post subject: |
That bid is pretty high for how much effort it takes to paint those. It's pretty simple to take your valve cover off and clean it up and paint it. Powder coating isn't a whole lot different from any engine high temp paint you can pick up at the local car store. I priced the stuff, the most youll spend is around 5 bucks plus a little elbow grease. _________________ My Old Porsche Thats Sold
http://members.cardomain.com/jatbballboy15 |
jpab924
Joined: 03 Nov 2002 Posts: 1538 Location: Crown pt. IN. 50 miles southeast of Chicago Ill.
Posted: Mon Dec 02, 2002 1:14 pm Post subject: |
I have a different opinion on powdercoating.----> It is much more durable than any in the can engine enamel.
When you powder coat something, the part has to be completely stripped to the bare metal with either an abrasive blaster or chemically stripped.
The electrostatically charged powder is then applied to the part which is grounded. You then bake the item in an oven and the powder coating melts. Providing for a very durable finish.
Using engine spray in a can, does not in way match the durablity of a piece which has been powdercoated. It may be alot cheaper, but you will find yourself doing the same job again down the road.
Did I mention you can get stuff powdercoated in any color you want?
Just my opinion. |
Posted: Tue Dec 03, 2002 3:35 am Post subject: |
agreed that is why people powder coat wheels instead of painting them _________________ 3 928s, |
speedsta2003
Stu2j
Posted: Wed Dec 04, 2002 7:29 am Post subject: |
Lizard wrote: | well u can always get it and then put it on at next engine service |
I decided that I wasn't even going to try if the price went over $200. Wouldn't you just know the thing sold for $202.50.
It never fails.
Oh well, another will pop up eventually. That was a very nice cover. Be nice to see one for the NA since that would be much easier to swap out. _________________ -Stu
81turbo
Posted: Wed Dec 04, 2002 7:41 am Post subject: |
Stu, last time I checked both of your cars are NA. |
Stu2j
Posted: Wed Dec 04, 2002 8:10 am Post subject: |
81turbo wrote: | Stu, last time I checked both of your cars are NA. |
Yeah yeah... I know.
It has just become commonplace for me to refer to the cars is the NA and the S.
Sounds just as dumb to say the 924 and the S. If you say 924S, it can be confused with 924s (more than one 924). Referring to them by color won't work here but is the only way where my wife is concerned. I could probably just refer to them by year but what happens when I get the turbo?
It's all just so confusing _________________ -Stu
924 turbo
Joined: 02 Nov 2002 Posts: 1566 Location: Simi Valley, CA, USA
Posted: Wed Dec 04, 2002 9:16 am Post subject: |
Stu: Why not just have your stock 924 valve cover powdercoated? _________________ Jon Furst |
Stu2j
Posted: Wed Dec 04, 2002 10:03 am Post subject: |
924 turbo wrote: | Stu: Why not just have your stock 924 valve cover powdercoated? |
Ok, ok... you're on to me. I'm just lazy and it's really ok by me if I find one already done
Actually, I haven't really looked for anyone local that does it. I guess I probably should eh _________________ -Stu
