TYPE111
Joined: 09 Feb 2014 Posts: 76 Location: Perth, Western Australia
Posted: Tue Dec 16, 2014 10:37 pm Post subject: Help! Indicator Stalk Gone Flaccid |
After finally getting round to fitting an original coolant tank so I can see the coolant level (and getting rid of the metal one I had where the level was guesswork) I took the car for a spin.
Indicated to turn left and the stalk has gone all floppy. It will go onto full beam if I pull it towards me but no right or left is possible.
So how do I remove the cowling from around the steering so I can see what is broken? Do I have to remove the steering wheel? If so is the horn pad (3 spoke type) just removed by pulling?
Am really at a loss and hacked off as Xmas is coming, the missus is whinging, and I can't the drive the car for the kids! _________________ Trust, Then Verify |
Posted: Wed Dec 17, 2014 12:09 am Post subject: |
Ok,
pop off the rubber horn pad, might take a bit of force and generally helps if you get one side started first... remove horn connection from spade terminal
need a 24mm socket and long extension on a ratchet and get the nut off..
pull the steering wheel off...
undo the three long screws with a flathead screwdriver (check these haven't already ripped the threaded section out of the cast aluminium ignition housing) this is a common problem on the three screw setups...
undo the electrical connections and lift off the indicator stalks...
imagine something plastic has cracked or snapped...
if looking at replacements parts match the same stalks as you have, the four bolt setup is completely different in just about all the electrical connections to the ignition housing/stalks.
TYPE111
Posted: Wed Dec 17, 2014 12:13 am Post subject: |
Cheers Stu, worst fears confirmed. Oh well, something to do tomorrow I guess. _________________ Trust, Then Verify |
TYPE111
Posted: Wed Dec 17, 2014 1:52 pm Post subject: |
Wheel off, 4 screws removed but cannot get the thing to come forward more than 10mm
Turns out the metal round bit attached to the stalk is in an extra two pieces, but how do I remove the stalk and fit another - which I still need to source. _________________ Trust, Then Verify |
Posted: Wed Dec 17, 2014 1:56 pm Post subject: |
Wait, have you tried stroking it? _________________ Toofah King Bad
TYPE111
Posted: Wed Dec 17, 2014 1:58 pm Post subject: |
No but I swore a lot. _________________ Trust, Then Verify |
Posted: Wed Dec 17, 2014 2:33 pm Post subject: |
I heard there's different treatments available for that condition.
However a turn signal that stays on for more than 4 hours may be and indicator of a greater issue and you should seek professional help. _________________ Stefan
!tom
Posted: Wed Dec 17, 2014 6:01 pm Post subject: |
| TYPE111 wrote: | | Wheel off, 4 screws removed but cannot get the thing to come forward more than 10mm |
Undo the connectors. On my car, there's two of them at the bottom end of the steering column. Then it should pull straight out. _________________ 78 924 NA
5-lug |
TYPE111
Posted: Sat Dec 20, 2014 11:12 pm Post subject: |
Found three connectors at the back of the column, unplugged all three and removed the hub. Yay!
Do I need to remove the curly clip on the right and then will it all come apart?
Put it all back together again and found the wiper is on intermittent even in the off position. Any thoughts????
TIA
David _________________ Trust, Then Verify |
Posted: Sun Dec 21, 2014 3:04 am Post subject: |
| TYPE111 wrote: | | Put it all back together again and found the wiper is on intermittent even in the off position. Any thoughts???? |
Switch is broken. . .my current least favorite NLA part. _________________ Toofah King Bad
