1979 931 build
Goto page Previous  1, 2, 3, 4, 5, 6, 7, 8  Next
PostPosted: Tue Nov 18, 2014 2:39 pm    Post subject: Reply with quote
Cut them behind the radiator mount, then make longitudinal cuts (think banana peel). Crunch cut ends together to make box section smaller, and tap on your new piece. When it's lined up, weld.
PostPosted: Tue Nov 18, 2014 10:10 pm    Post subject: Reply with quote
BTRacing wrote:
So you guys are suggesting cutting of whole frame rails?
No. Unpick the front end from the front of the chassis rails. I didn't cut the rails themselves on my 931. It went back on as if totally original. Photos in my threads linked in my signature.
PostPosted: Wed Nov 19, 2014 12:48 am    Post subject: Reply with quote
I like the license plate, DDR, how appropriate~!
PostPosted: Wed Nov 19, 2014 1:00 am    Post subject: Reply with quote
though DDR did have a severe lack of 924s...
Will be interesting to follow this build, keep it up !
BTRacing
PostPosted: Wed Nov 19, 2014 12:32 pm    Post subject: Reply with quote
Here is few pictures from today.I started taking front end apart.Removed headlights assembly,fenders,lower valance and some AC components.
I am trying to save as much weight as possible.
I repaired passenger side floor and welded in new/old seat brackets.
Not much but some progress.
www.btr-chicago.com
1977 924 Martini
1979 931 GTR Le Mans replica to be
1993 Mercedes 190E Sportline LE, one of 700 made
2020 Ford F350 Tremor daily driver/tow pig
1974 Moto Guzzi Cafe Racer
2002 Formula Fastech 382
BTRacing
PostPosted: Wed Nov 19, 2014 12:34 pm    Post subject: Reply with quote
Here is a picture of my headlight kit and some of the customers cars that I am working on right now.
www.btr-chicago.com
1977 924 Martini
PostPosted: Wed Nov 19, 2014 7:31 pm    Post subject: Reply with quote
You cut too much off each end of the 951 front end!! You should have joined on the inner wings where there is a factory seam.
951 panel in silver, stock panel is white
silver 951 front end grafted onto uncut & white chassis rails
full factory look using 951 front, rad and IC mountings plus super rare factory 931 bolt on badge panel
BTRacing
PostPosted: Thu Nov 20, 2014 5:46 am    Post subject: Reply with quote
I bought it like that
I am working on it right now,will post some pictures tonight
www.btr-chicago.com
1977 924 Martini
BTRacing
PostPosted: Thu Nov 20, 2014 2:25 pm    Post subject: Reply with quote
So here is todays progress on the car.
Removed badge panel,cut out front end parts and reinstalled 951 pieces and fitted intercooler.Pretty happy with the way it came out.
[URL=http://s1090.photobucket.com/user/btracing/media/2014-11-1917
www.btr-chicago.com
1977 924 Martini
BTRacing
PostPosted: Thu Nov 20, 2014 2:27 pm    Post subject: Reply with quote
www.btr-chicago.com
1977 924 Martini
PostPosted: Thu Nov 20, 2014 7:27 pm    Post subject: Reply with quote
Very good
PostPosted: Fri Nov 21, 2014 12:37 am    Post subject: Reply with quote
Like your work...BT!
BTRacing
PostPosted: Fri Dec 12, 2014 12:41 pm    Post subject: Reply with quote
I have new to me late offset front spindles and hubs from 944 Turbo.It will be nice upgrade including Turbo brakes.
www.btr-chicago.com
1977 924 Martini
PostPosted: Fri Dec 12, 2014 4:53 pm    Post subject: Reply with quote
What struts will you run? What front arms will you run?
Late spindles means late struts, late struts mean late front arms unless you modify something.
PostPosted: Fri Dec 12, 2014 6:42 pm    Post subject: Reply with quote
What wheels are you going to run on that car?
Page 2 of 8
