Torque tube bearings
homey
PostPosted: Mon Oct 20, 2014 10:37 pm    Post subject: Torque tube bearings Reply with quote
The local (Central VA ) mechanic says he does not know anyone doing torque tube bearings. . Anybody out there know how / where / cost of doing these bearings ?
Thanks
1980 924 NA, M471
1972 914 1.7
1992 HD 1200 Sportster
2002 HD TC 88 Superglide
1994 Jeep Grand Cherokee, converted to 5 Speed
PT Cruiser ,
and 5 Jetskis
PostPosted: Tue Oct 21, 2014 12:11 am    Post subject: Reply with quote
Do it yourself:
http://www.clarks-garage.com/shop-manual/trans-05.htm
or give your "mechanic" these instructions and be prepared to pay quite a lot in labor.
924 NA bearings have a smaller ID than the 944 and 931 bearings, but the same OD. When I did mine I had to buy the bearings from a local bearing supply house. Cost about $80 or so.
A little search here should get you some part numbers or dimensional information for those bearings.
GeorgeV
PostPosted: Sun Oct 26, 2014 5:20 pm    Post subject: Reply with quote
What issues would this fix? My car is 30+ years old and must need the TT bearings replaced. But would I notice it if I had them done?
1981 932 with mods:
http://www.924board.org/viewtopic.php?t=37921
jason c
PostPosted: Sun Oct 26, 2014 11:09 pm    Post subject: Reply with quote
You'll know when they need to be done if you hear them growling or feel vibration in the TT.
v8carreragts
PostPosted: Tue Oct 28, 2014 4:06 am    Post subject: Reply with quote
This guy can do it as well. I understand his bearings are outstanding.
http://www.blackseard.com/site/
I did do my own though.
84 944--924 Carrera GTS clone w/520HP Chevy 302 V8--RUNNING!
2015 AUDI Q7
2013 Dodge Charger R/T AWD HEMI
2013 Chevy Cruze
PostPosted: Tue Oct 28, 2014 4:58 am    Post subject: Reply with quote
Or like mine, were rusted nearly completely solid due to water leaking into them from draining the floorboards.
jason c
PostPosted: Tue Oct 28, 2014 11:39 am    Post subject: Reply with quote
Water would definetly trash them. How did that happen? The floors are lower than the tube. The only holes in the tube on top are for the shifter mounting bolts. Are you sure it wasn't from missing plugs the access holes?
PostPosted: Tue Oct 28, 2014 12:32 pm    Post subject: Reply with quote
Could be, but it was rusted front and rear.
jason c
PostPosted: Tue Oct 28, 2014 12:55 pm    Post subject: Reply with quote
If water does get forced through one of the bearings, it would just slosh back & forth as you drive. Even if the car wasnt being driven any water sitting in the tube would destroy both bearings just from moisture being in there. Temperature changes will turn the moisture into condensation inside the tube.
Those plugs are important if the car will be driven in the rain or sitting over moisture.
Captain_Kirk
PostPosted: Wed Oct 29, 2014 12:50 pm    Post subject: Reply with quote
Ding Ding Ding... V8carreragts came up with the correct answer the quickest. Blackseard.com
Constantine is great to work with. He had originally had only the 25mm bearing inserts or bigger, but when I needed 19mm inserts for my early 924, he ramped up production using a sample from me to build them.
1977 924na BlackSeaRD.com Torque Tube SuperBearings, Xenon air dam, 200# Weltmeister springs, Bursch header, 944 exhaust, Audi throttle body
jazz guy
PostPosted: Thu Oct 30, 2014 1:13 am    Post subject: Reply with quote
I'm looking to use them too but it looks like they are in the middle of a move right now and are not open for business yet.
'81/'81/'82
Britain
PostPosted: Thu Dec 25, 2014 10:17 am    Post subject: Reply with quote
I have some brand new stock bearings for sale. They are for the 931 diameter shaft.
-Britain
